pethier Posted September 21 Share Posted September 21 Cat is turning in much better now I moved the slider blocks about 40mm closer to the bar. I think I will try another 10mm or 20mm at tomorrow's autocross. I hope the layout is easier to follow tomorrow. I had a few DNFs. In some of those same spots on my clean runs I hesitated there and slowed out. My best (I hope clean) time was 60.xxx and I know that there were some other cars that did 57.xxx and 58.xxx. Part of if may be that there were places I should have gone to 3rd gear, but I am still not that confident in fast left-hand shifting. I used to toggle back and forth between 2nd and 3rd all the time in my Europa, but I using my right hand. I'm pretty profoundly right-handed. Every club is different and has different culture. These folks had a very-light turnout. They elected to do 6 runs in one heat for half the field and then six runs in one heat for the other half. This didn't give enough time between heats for sway-bar tinkering. The good news though, is that if I lie down on the asphalt. I can reach the single hex bolt that acts as a setscrew on each block. I had been looking forward to a practice day with my club to do this sort of thing, but I tested positive for Covid the Wednesday before the event, and missed the practice day. I wanted to be more-prepared than this for the LOG autocross next Saturday. C'est la Vie. I have to remember that this is a totally-stock 1700 Super Sprint and I can't expect miracles. 1 Link to comment Share on other sites More sharing options...
panamericano Posted September 21 Share Posted September 21 " C'est la Vie. I have to remember that this is a totally-stock 1700 Super Sprint and I can't expect miracles." If you're fast it's the driver. If you're slow, it's the car. 1 Link to comment Share on other sites More sharing options...
pethier Posted September 21 Author Share Posted September 21 13 minutes ago, panamericano said: " C'est la Vie. I have to remember that this is a totally-stock 1700 Super Sprint and I can't expect miracles." If you're fast it's the driver. If you're slow, it's the car. It's the driver. I had trouble seeing a few spots on the course and didn't have the confidence to stay on the power. Link to comment Share on other sites More sharing options...
pethier Posted September 23 Author Share Posted September 23 I went a little further with the blocks. Since I didn't have a lot of time, I did just lie down on the asphalt, so I am not sure how far I really moved them. The course was very-similar to the day before. The car was better-balanced. I again got six runs with no real break between them. I wound up in the middle of the pack overall. Every run was clean and every run was faster than the one before it. I believed that FTD was 53:9xx and my best was 57:1xx. Did go to third gear more, was still pretty-clunky about it. The car was just a little loose in the fastest parts of the course. It should be just about right for the LOG autocross. Link to comment Share on other sites More sharing options...
