fastg Posted November 4 Share Posted November 4 (edited) https://grassrootsmotorsports.com/news/njmp-to-add-the-devils-pass-to-its-thunderbolt-circuit/ Edited November 4 by fastg 1 1 Link to comment Share on other sites More sharing options...
Croc Posted November 5 Share Posted November 5 It would have been done last year with the repave, however, they ran out of time (or forgot - depending on who you talk to) to get the NJ EPA to approve the modifications to the site for drainage. I think they were required to add a new drainage pond and that type of earth moving is expensive and time consuming. I have not heard if it is definitely going to be done over the 24/25 winter but the impetus for the change was from NASCAR (for ARCA series) as they thought it would suit the cars better. The Octopus section was always a contrived corner. This should make the overall circuit flow better. It will reduce top speed down the straight to Turn 1 as the straight effectively began where you exit the Octopus - I don't lift throttle from there until braking at Turn 1. Link to comment Share on other sites More sharing options...
