Detroiter Posted February 15, 2025 Posted February 15, 2025 I’m looking for some black sports seats with cut out for harnesses. any recommendations where to look as I’m struggling to find narrow ones
11Budlite Posted February 17, 2025 Posted February 17, 2025 If you're not looking for the standard Caterham or Tillet offerings you could check out KitCarDirect: https://www.kitcardirect.co.uk/collections/caterham-seat Are you looking for a padded seat or a CF/Fiberglass seat? Just an FYI, I've been able to use the stock 2019 Caterham S3 seats with a 6-pt harness on track without any issue. You just run the crutch straps on top of the seat base and sit on them before buckling up.
CBuff Posted February 17, 2025 Posted February 17, 2025 I have the leather seats in my 420. And just had a hole cut thru the squab. It has worked well. I thought I would only use on track but now I run crutch all the time. It keeps the buckle located and is perfectly comfortable. 2
Detroiter Posted February 22, 2025 Author Posted February 22, 2025 That looks awesome, I’m looking for something similar but for the top of the seat. Didn’t think a hole could be made nicely but definitely underestimated what’s possible. Did you find a local service for the work you got done?
CBuff Posted February 22, 2025 Posted February 22, 2025 My importer up in buffalo found an upholsterer who did it. I can track down the name but don’t think it was a specialist. I works well
