Where can I get rear caliper spacers quickly?
I'm looking for spacers for my rear caliper to hub mount.
The kit came with 4 but they're all roughly different. It seems like the most important spec are that they're a 10mm bore, and then the thickness (length) are all equal such that the brake disc is in the middle of the caliper.
3 of mine are 6.4mm thick, one of them is 7mm thick. I visited 5 hardware stores today and wasn't able to find anything. The closest I've found was 3/8 inch bore, quarter inch thick (6.3mm).
Ideally, I'd like to get 1 full set of each of the thicknesses so that I can see what works for my calipers.
If anyone knows where I can get them, that'd be great, otherwise I'll have to ask my dealer to ship me some.
I did check McMaster Carr already.
You talking about these?
I would contact dealer to get the right ones even if you find something quickly to keep the project moving. They are pretty easy to swap out.
