Hydraulic Hand Brake
solder_guy
Wait a second- is somebody planning to either A: Drift a Seven or B: Rally a Seven? Because those are the only two reasons I can see for buying a hydraulic hand brake.
what's wrong with drifting a seven? :D
[Greek to you]These are very common in my world of off-pavement travel, but they are referred to as cutting brakes. To utilize this, an individual disengages the rear wheels, creating a front wheel drive situation, they then apply the brakes to the rear wheels, and by turning sharply to one side or the other can literally pivot around the rear axle of the vehicle. Makes for some pretty spectacular maneuvers on tops of rock faces.
[/Greek to you]
:D
Oddly enough, fiddle brakes (cutting brakes) were incorporated into Colin Chapman's first design which subsequently became the Lotus Mark 1. This car was designed for trials competition. The fiddles allowed sharp turning maneuvers in the off road segments of the trial.
I guess that make this discussion appropriate for a Sevens forum. :D
