Darren Posted Monday at 07:14 PM Posted Monday at 07:14 PM THIS is not your typical Seven. The range-topper for over a decade, this specification commemorates 50 years of the Lotus/Caterham lineage (1957–2007). Finished in Ballistic Orange with black accents, this British icon is powered by the bespoke dry-sump Cosworth 2.3L Ford engine producing 260 hp, breathing through roller-barrel throttle bodies and a Westermann carbon ram-air intake. Power is delivered through Caterham’s own close-ratio 6-speed manual gearbox housed in a lightweight aluminum casing, paired with a 3.62 limited-slip differential. At just 1,395 lbs, performance is immediate and intense. The CSR 260 represents the most advanced evolution of the venerable Caterham platform, built around the upgraded CSR chassis—25% stiffer than standard—paired with fully independent double-wishbone rear suspension and pushrod inboard front suspension. The result is a Seven with markedly improved composure, grip, and stability, yet this upgraded version sacrifices none of the raw, analog driving experience. Legally registered in California in 2014 as an SPCNS with a 1957 Lotus designation, the car is permanently smog-exempt and retains its SB100 certification plaque in the engine bay. The car has current DMV tags and a clean title. Owned by the seller for 12 years, and with 7,300 miles on one of the last custom Cosworth crate engines to leave the line, the car presents in excellent condition following a mechanical refresh by Kampena Motors and a subsequent professional repaint in 2025. In December 2015, with chassis mileage at 4,985, the seller replaced the original engine with a brand-new Cosworth CSR260 crate engine of the same specification, as the original motor had several technical issues, incomplete service history, and had spent its life at 6,800 ft above sea level. The chassis has 12,200 miles since new, while the replacement engine has 7,300 miles and runs beautifully. The car has spent approximately two-thirds of its life canyon carving, blatting, and cruising, with the remaining third used on track. Key Highlights: • CSR chassis • Independent rear suspension (double-wishbone) • Pushrod inboard front suspension • Cosworth 2.3L dry-sump engine (260 hp) • Roller-barrel throttle bodies • Caterham close-ratio 6-speed manual gearbox (aluminum casing) • 3.62 limited-slip differential • Superlight roll cage, built-in fire suppression system, cutoff switch • Lowered floors, reinforced driver’s side, Tillet carbon/Kevlar seat, MOMO quick-release wheel, color-coded tonneau cover • AP brakes, uprated suspension, quick-ratio steering rack, dash-mounted shift-light sequencer • 15-inch alloys with new Toyo R888R tires all around Upgrades & Supporting Mods: • Westermann Motorsport carbon ram-air intake • Secondary oil cooler to better sustain track use • Reinforced rear diff mount/strut tower • Lightweight battery, reduced-drag lighting • New carbon rear protection panels Recent Service (2025, minimal use since): • New front brakes (calipers, discs, pads) • New half shaft • Differential refresh • Fuel lines replaced • Full service and brake flush • New Toyo tires front and rear Included with Sale: • Original order documentation & MSO • Clean Carfax • Extensive maintenance records • Full set of unused wheel bearings front and rear • Cat-delete pipe (standard exhaust with catalytic converter included) • Additional unused harnesses Not Equipped With: • Spare Tillet seat • Heater • Carpets (except transmission tunnel) One of the last Cosworth-powered CSRs, and arguably the most capable and complete Seven ever built. Engineered with true motorsport intent, this is an unapologetic and unforgettable enthusiast car—equally exhilarating on a country-road blat as it is on track. Worth repeating, even for those in the know: a 260 hp Caterham IS the therapy! And this one is ready for its next chapter. $53,000obo 6 1
rallyguy Posted 6 hours ago Posted 6 hours ago On 5/11/2026 at 12:14 PM, Darren said: s mileage at 4,985, the seller replaced the original engine with a brand-new Cosworth CSR260 crate engine of the same specification, as the original motor had several technical issues, incomplete service history, and had spent its life at 6,800 ft above sea leve Hi Darren, great well presented car and specification. Curious how difficult it would be to remove passenger tonneau, add passenger seat, belts and windshield?
KnifeySpoony Posted 5 hours ago Posted 5 hours ago (edited) You can run a windshield with the SLR cage, but not with doors. You'd have to switch to a different cage/rollbar type if you want full weather gear. Edited 4 hours ago by KnifeySpoony 1
Darren Posted 4 hours ago Author Posted 4 hours ago Thanks for reaching out. KnifeySpoony is correct. An SLR cage is normally accompanied by a removable half screen (Aeroscreen) or a custom windshield. I left the windscreen wipers motors on for the possibility of a custom glass screen. The tonneau is bolted on but can be removed with appropriate tools. I have some race seat runners that can be bolted back into the floor pan. I also have an unused set of Caterham harnesses that would work with a new passenger seat.
11Budlite Posted 1 hour ago Posted 1 hour ago I wish this was for sale last year when I was looking for a Duratec-powered track car. Really nice-looking CSR, good luck with the sale!
Darren Posted 1 hour ago Author Posted 1 hour ago 1 minute ago, 11Budlite said: I wish this was for sale last year when I was looking for a Duratec-powered track car. Really nice-looking CSR, good luck with the sale! Thank you! Someone is going to get a special car. In my humble opinion, Cosworth CSRs were pinnacle. 1
