I sent Josh my r400 as the Bimmer dif was toast and I just didn't feel like doing the work myself.... I always have but am at the point of let someone else do it if I think they'll do it right.
Steve Perks (Tracsport) sent the LSD he built to Josh (40 lb. pre load 3.64 gears) directly whilst I sent the car.  I also had the shocks changed back to the original adj. Bilstein's and the height set to fast road, and the toe/camber (when I bought the car both sets of shocks came with).... that is the same set up Josh uses on his 420r.  I find the Bilstein's to be as firm on hard corners (round a bouts) as the Nitrons (but they were on their lowest setting...which is firm, can't imagine the high settings/track only).
They replaced the accessory Gates belt and I bought 4 new wheels from Beachman Racing (thanks, Bruce, very quick and reasonable shipping).
The car came with 4 8x13 wheels with a 185/55 mounted up front.... no bueno... I suspect the seller bunged a wheel and used what was available.  Now properly shod.
The Tracsport is much quieter and less 'clunky' than the old Bimmer...especially no high pitched whine and strange noises.  On the road I'll never really test it at its limits and that's fine.
I found Josh to be very helpful/informative and very fair in pricing.  Ram Logistics (transport out of Phx, Az.) was also professional and very reasonable and have worked with Josh on numerous occasions.  Being close didn't hurt either.
  • Like 4
  • Thanks 2
  • Haha 1
Josh sent me a new style pick up complete gratis..... said the old style are touchy and as they had to remove it when they did the LSD he'd just send me one.
On and working just right...with the wheel off and key on you can see the pulsing when you spin the hub....
Everything is just as I want it now...proper street height. firm but not rock like suspension and I do like the new wheels...
