gjz30075 Posted July 28 Posted July 28 I have what looks to be a triangular mount for a differential. I'm not sure what it's called but it is straight; no kinks or bends. $100 . Shipping will be from the Atlanta area. Contact - GJZ30075 -at- gmail.com
Croc Posted July 28 Posted July 28 Its called an A Frame. Its part of the rear suspension for a Caterham. It may be straight but does it have any dings or divots in the powder coat that would be a harbinger of possible damage? Then to ask the second obvious question - which model Caterham is it for? An S3 or an SV? Then which S3 chassis - imperial or metric? From the design at the top of the A, I suspect it is an S3 imperial but a prospective purchaser will need to validate that with you.
gjz30075 Posted July 28 Author Posted July 28 All fair questions. I'm an Elan guy and my knowledge re: Caterhams and 7s is limited. I'm selling this as part of an estate of a deceased friend who was a Europa owner and possibly a Caterham owner in the distant past. It's painted and has numerous scratches but no dings or dents. It measures 36 1/8" across the bottom of the 'A', end to end. From the center of the center bush (no bush installed) to the bottom of the 'A' tube, the measurement is 10 3/4" Hope this helps someone. Thanks. 2
gjz30075 Posted July 28 Author Posted July 28 My 7 source says it's for an S2 7 with an original axle.
