Scott_ Posted Saturday at 04:17 PM Posted Saturday at 04:17 PM I have a ‘99 Caterham with the 1.8 K-series VVC and the original tank and in-tank fuel pump. Later this year I’m swapping to a Esslinger stroked 2.3 Duratec and would like to upgrade the pump now while the K-series is still in the car. Has anyone upgraded the pump in the original K-series carrier? I’ve seen the Walbro GSS242 mentioned. I’m also looking at a DW200 255 LPH, since it’s readily available in the US. What pump did you use, and how did you modify the original carrier? Scott
pethier Posted Monday at 02:45 PM Posted Monday at 02:45 PM Scott, Would you please educate me on where this pump mounts? I have an unused fuel tank for my 1991 deDion Caterham. Unfortunately, I do not have the carrier. The in-tank mounting port is not on the top of the tank, but on the car-right side (end?) of the tank. I'd like to obtain a carrier. The engine in the car is a Ford Zetec with Hayabusa injection.
Scott_ Posted Monday at 03:11 PM Author Posted Monday at 03:11 PM 13 minutes ago, pethier said: Scott, Would you please educate me on where this pump mounts? I have an unused fuel tank for my 1991 deDion Caterham. Unfortunately, I do not have the carrier. The in-tank mounting port is not on the top of the tank, but on the car-right side (end?) of the tank. I'd like to obtain a carrier. The engine in the car is a Ford Zetec with Hayabusa injection. On my car the pump assembly is in-tank and goes into the side of the tank so the tank has to come out for service/replacement. I'm not sure about your year car but the assembly for mine came out of some Rover. Perhaps if your tank is an original Caterham tank you could send a pic to Caterham and ask if they carry the assembly or have a cross reference that would work for yours. Scott
