Origin7 Posted September 23 Posted September 23 I am planning on rebuilding my differential and installing a Quaife LSD. Considering changing the gear set as well. Can anyone recommend a good service manual that I should acquire? Thanks!
11Budlite Posted September 24 Posted September 24 I have a Haynes Ford Sierra V6 manual and it has just basic information on the differential, like R&R and seal replacement. I think you're going to have to get a Ford factory manual to get the info you need to do what you're looking to do. The Mercury Merkur XR4Ti might be the same exact rear end as the Sierra. If it is you can check out this online manual here: https://archive.org/details/1985-1988-merkur-xr4ti-shop-manual/page/n359/mode/2up Look at section 15-03, starting at pg 347. Hope this helps. 1 1
