RingCat8 Posted November 9 Posted November 9 Going to throw this out there. Not on 7 but I was tracking an 88 325IS BMW that was doing similar things under load, took a bit but found a ground strap had rotted out and became loose. So, when under load and engine would lean thus pulled out just enough to cut out. Just a thought.
wdb Posted November 10 Posted November 10 On 11/9/2026 at 10:41 AM, RingCat8 said: Going to throw this out there. Not on 7 but I was tracking an 88 325IS BMW that was doing similar things under load, took a bit but found a ground strap had rotted out and became loose. So, when under load and engine would lean thus pulled out just enough to cut out. Just a thought. That reminds of the time a friend called for help replacing the throttle cable on his MGB. When I took a look at the cable I saw that it had siezed up due to the plastic lining having melted. Root cause was a broken ground strap; the engine and everything attached to it was grounding through the cable, making it get very, very hot.
