Mawgui Posted 20 hours ago Posted 20 hours ago I would like to reinstall the heater in my recently purchased 1997 Caterham 7. I understand there is a range of views on the usefulness of these, but things have started getting cold in Michigan and I would like to give a heater a shot. My heater is an older version with a "7" molded into the front of the case. Unfortunately, the heater that came with my car was disassembled and seriously damaged. The case needs to be patched and reinforced. I have a collection of pieces and can deduce where most of them go... but such is the damage that others are a mystery. I have searched the internet and these forums. I have found some great discussions for newer cars, however, these aren't sufficient for what I need to do. I may have missed something but I have not found what I need. I am hoping that a member might have access, for the older style heater and case, to an exploded view of the components (matrix, case, blower, vents, etc.) or a comparable set of photos to the one below. Thanks!
Croc Posted 14 hours ago Posted 14 hours ago I assume you trawled the build manuals in the Library section of this site? https://usa7s.net/ips/files/ I skimmed just now but did not see anything like what I think you are wanting. Which version heater you do have? Its not the box in the illustration you posted as that came in around 2000. Playing forward, does it make sense to reinstall the same heater? Could you install a later heater? Plumbing approach is similar. Car builder solutions have a range of aftermarket kit car options: https://www.carbuilder.com/pages/search-results-page?q=heater&_su_rec=KMwD0C3XidN0CUM7HRUOJbR_bnWK_7pBMsTTdvANTaXGhgQZR-fcuMkJCpd_ukKxS3L-1hwa7wcpCIQfQh54YDCf_i-iuw_VlwYMgo_bORQpNsf_Op-uKDsHZ2-cCWsEAn4hnvuhrYhtMwgKmshFU7n10qxNhaV3sggGBE_0mtgK99RtJpate8bYHE-gZ5OnEmxnKiiQlo7F4i49eCxwUwQF_WkXRVHJ_hv-qawKplyq96W64jKU_IzL4KBw2YCVH_FL3RI7U4Q2l4Uzgo0rHSa6-aLVBt13x7N2_3FgDlK_QLJMxyfCSdRQLecS8eBgbIld4106M9qRk5-pXFi5nviSTLg&_su_rec_id=f4d18428-e23b-440a-87fa-b6d60fcddb8e-1794823031&page=5 1
NSXguy Posted 4 hours ago Posted 4 hours ago You’re not driving fast enough to activate the radiant heat premium feature in a se7en - vital for cold weather driving 😬 1
theDreamer Posted 4 hours ago Posted 4 hours ago This is the heater in my 1993 HPC. It appears to be longer than the one in your photo and does not have the embosed 7. I do not recall seeing any photos in my build binder but I'll dig it out and have look through when I get a chance.
