T9 Trans Cover/Fill Plug
11Budlite
One of the best mods I did to my T9 when I rebuilt it with close ratio gears was to put a fill plug in the top cover. Anybody who has had to access the fill/level plug in the drivers footwell knows what a PITA that job is, especially when the DPO drilled the access hole in the aluminum offset from the plug! :ack: I bought a Quaife top cover from Taylor Race Eng which I think I read on blatchat was supposed to reinforce the cast iron case which is prone to cracking. The cover comes tapped (from memory I think 3/8" NPT) for the breather filter, but is not tapped for a fill plug. It does have a boss right next to the "Q" that I drilled and tapped 9/16-18 to accept a fill plug. Here's a photo of it installed on the tranny with the breather filter, and the Birkin slave cylinder and mounting block which has to be slightly modified because of the increased thickness of the cover.
http://www.usa7s.com/aspnetforum/upload/49619016_IMG_9504.JPG
And here's a picture of it with the tranny installed in the car:
http://www.usa7s.com/aspnetforum/upload/1889017534_Trans Fill Plug.JPG
Now it's just a matter of removing the plug, making up a simple dip stick, and being able to check and fill the tranny from under the hood instead of from the footwell. :) I ended up making a dip stick out of an old wiper blade metal reinforcement that I bent (so it wouldn't fall down inside), and center-punched for a full level mark. Like this:
http://www.usa7s.com/aspnetforum/upload/1000234743_20080808_0001.JPG
I know the price of the cover has gone up quite a bit from when I purchased it, but the same type of plug has been done with the stock stamped-steel cover. If anybody is interested in going the Quaife route, I have some extra 9/16-18 plugs you can have, and the matching tap that you're welcome to borrow. Or send me your cover and I'll put it in the drill press and drill/tap it for you, and send it back with a new plug installed. All you'd have to do is cover shipping...
Bruce :7drive:
That is what I did when I had the engine out lately. But I am envious about your really spiffy looking box lid.
I welded a 1/2" fine thread hex nut to the stock lid (because the lid is a bit thin for direct threading) and used an off the shelf drain plug. Plastic stick with notches as dipstick.
Oh well, in the dark cave of the tranny tunnel you can't see it, anyway :D
Gerthttp://www.usa7s.com/aspnetforum/upload/943447125_P1000760.JPG
  • 5 months later...
