slngsht Posted November 1, 2006 Share Posted November 1, 2006 Measure twice, cut once? Or is it measure 3 times, weld once? http://www.usa7s.com/aspnetforum/images/emoticons/banghead.gif I've been working on fabricating the bracket for my cycle fenders. Simple task, except the welder is at my friend's house, etc... So I'm on the last piece to weld for the driver side. Line everything up. Take it off the spindle and go to weld it. Right before welding, I realize I have one of the pieces backwards. To make sure I have it right, I do the whole setup again, and I still got it backward http://www.usa7s.com/aspnetforum/images/emoticons/cuss.gif I shut the welder off and came home Link to comment Share on other sites More sharing options...
locostv8 Posted November 1, 2006 Share Posted November 1, 2006 "I cut it 3 times and it is still too short". hehe Link to comment Share on other sites More sharing options...
stevet Posted November 1, 2006 Share Posted November 1, 2006 Mazda. You are not alone... Link to comment Share on other sites More sharing options...
Dave W Posted November 2, 2006 Share Posted November 2, 2006 You do not start counting until AFTER three tries! The first is the design concept The 2nd is the prototype The 3rd is the actual part. Been there, done that Dave W Link to comment Share on other sites More sharing options...
slngsht Posted November 2, 2006 Author Share Posted November 2, 2006 I went back last night, and got all the welding on the driver side done. Now all I have left is drilling holes to connect the fender bracket to the spindle bracket http://www.usa7s.com/aspnetforum/images/emoticons/thumbsup.gif I'm going to drive it with 1 fender for a little bit to make sure wind and bumps don't cause it to fly off. Then the fun part starts: making the passenger side look like the drive side http://www.usa7s.com/aspnetforum/images/emoticons/willy_nilly.gif Link to comment Share on other sites More sharing options...
solder_guy Posted November 2, 2006 Share Posted November 2, 2006 Then the fun part starts: making the passenger side look like the drive side http://www.usa7s.com/aspnetforum/images/emoticons/willy_nilly.gif Well .. just make sure that you make a Mirror Image of the driver side bracket! http://www.usa7s.com/aspnetforum/images/emoticons/wink5.gif Bracket pics?? Rob Mitchell solder_guy2006-11-02 11:02:36 Link to comment Share on other sites More sharing options...
slngsht Posted November 3, 2006 Author Share Posted November 3, 2006 Here you go... my first couple of welds came out crappy, so i gotta grind 'em and clean 'em up a bit. The fender is almost true. It'll take a little leaning to get the front just right. It is slightly off, but not bad at all. It does seem pretty stiff, but I won't know till I get her on the road. If that goes well, I'll take everything apart, sandblast and powdercoat (and I have a new lower balljoint. Not much left of the one in the pic). http://www.usa7s.com/forum/uploads/20061102_200027_CIMG1194.JPG http://www.usa7s.com/forum/uploads/20061102_200142_CIMG1196.JPGslngsht2006-11-02 20:51:56 Link to comment Share on other sites More sharing options...
solder_guy Posted November 3, 2006 Share Posted November 3, 2006 Looks good! BTW: What part is the replacement ball joint? Rob M. Link to comment Share on other sites More sharing options...
slngsht Posted November 3, 2006 Author Share Posted November 3, 2006 I forget the part number. Look in the tech section for the Rotus replacement part list. I ordered the Moog part number from Carquest. Link to comment Share on other sites More sharing options...
solder_guy Posted November 3, 2006 Share Posted November 3, 2006 I ordered the Moog part number from Carquest. Lower Ball Joints (Moog) K 8036 ? Rob M. solder_guy2006-11-03 04:19:35 Link to comment Share on other sites More sharing options...
Arya Ebrahimi Posted November 5, 2006 Share Posted November 5, 2006 How are you going to address the marks in the finish on the edges from the tooling when it comes time to powdercoat? I would think a little bondo and paint would be the better option. In fact I would probably rattle can it, as they are sure to be subject to rock chips and powdercoat is very difficult to touch-up. I would also coat the underside/inside w/ rubberized undercoating(also available in a spray can) to lessen the sound of rocks hitting the inside of the fender. It will also provide some impact resistance if a stray piece of gravel jumps up and hits the inside of the fender, it shouldn't leave a dent. Link to comment Share on other sites More sharing options...
slngsht Posted November 5, 2006 Author Share Posted November 5, 2006 I'm only going to powdercoat the steel brackets that connect to the upright. I'll either polish the fenders or paint them green. I have the spray on undercoating and plan to do that on the inside of the fender. Link to comment Share on other sites More sharing options...
