ottocycle Posted March 3, 2009 Share Posted March 3, 2009 I am playing with the Heretic and going through the process of lowering the engine for hood clearance reasons. What I want to know is how low your oil pan is. What clearance do people have between the road surface and the bottom of the oil pan and have you bottomed it? I remember Mazda telling me what clearance he is running but cannot remember. Any takers? Cheers- Dermot. Link to comment Share on other sites More sharing options...
slngsht Posted March 3, 2009 Share Posted March 3, 2009 well, my sump USED to hang about 3" below the frame, and I though that was a disaster waiting to happen. So I ran my frame about 5.5" from the ground with 2.5" of oil pan clearance. On the redesign I made the engine flush with the bottom by raising it in the frame. Now I run the ride height at about 3.5". Link to comment Share on other sites More sharing options...
Hank Posted March 3, 2009 Share Posted March 3, 2009 I run a MEGABUSA with a dry sump system so my oil pan doesn't protrude below the frame. [picture] Link to comment Share on other sites More sharing options...
scannon Posted March 3, 2009 Share Posted March 3, 2009 My Caterham oil pan has 2.5" of ground clearance without me in the car. I found some small scratches in the fins the last time I changed the oil. I think I did those getting into my previous trailer. I am used to driving a lowered Miata with about the same clearance but more front overhang so I am very careful around speed bumps and the like. Skip Link to comment Share on other sites More sharing options...
DB6 Posted March 4, 2009 Share Posted March 4, 2009 (edited) I have 2.5 on the pan , and 3 on the gear box armour ring. First thing I bottomed out on, (and ripped the honey comb off) was the side exhuast on the ramp in to the local post office. One thing to note as well, the clearance is def, lower with 2 ppl in the car than one( yeah I know it is obvious) , as I learnt with my son in the car going to the local Subway, nothing worse than hearing that scrrrrrreeeeeech. The closer it is to the ground the bigger the man. Edited March 4, 2009 by DB6 Link to comment Share on other sites More sharing options...
drew... Posted March 4, 2009 Share Posted March 4, 2009 about 2.5" with no one in the car - caterham S3 with SVT motor - I did have to machine down the motor mounts a quarter inch to get the variable cam timing solenoid to clear the hood during construction. I have also lowered my floors 70mm - which hangs ME right down there with the oil pan! Link to comment Share on other sites More sharing options...
DB6 Posted March 4, 2009 Share Posted March 4, 2009 about 2.5" with no one in the car - caterham S3 with SVT motor - I did have to machine down the motor mounts a quarter inch to get the variable cam timing solenoid to clear the hood during construction. I have also lowered my floors 70mm - which hangs ME right down there with the oil pan! Drew thats a huge drop on the floors (2 and 3/4 inches right), how did you do that? Link to comment Share on other sites More sharing options...
Alaskossie Posted March 4, 2009 Share Posted March 4, 2009 Gert, How much does that armor weigh, anyway?? That looks like the forestry skid plate I'm installing on my M-B Unimog 406, at about 85 lb.! Link to comment Share on other sites More sharing options...
slngsht Posted March 4, 2009 Share Posted March 4, 2009 Gert, How much does that armor weigh, anyway?? That looks like the forestry skid plate I'm installing on my M-B Unimog 406, at about 85 lb.! Unimog You have quite a unique collection of vehicles. Link to comment Share on other sites More sharing options...
drew... Posted March 4, 2009 Share Posted March 4, 2009 basically fabricated an aluminum cake pan with 1/2" tapered sides and replaced the flat section from the 1" square tube in front of the seats to the rear upright wall of the cockpit. three sides of the pan attach to the holes that formerly held the flat floor in place. The front of the pan attaches to the rear vertical surface of the brace in front of the seat. Link to comment Share on other sites More sharing options...
Alaskossie Posted March 4, 2009 Share Posted March 4, 2009 Slngsht, Can't help my fascination with odd mechanicals... (Somebody please stop me, before I buy again....!!). In addition to the 'Mog 406 double-cabin, I've got a Land-Rover-based 1990 MWG Esarco 8X8 truck with 4-wheel steering (one of 3 built) and on its way from Germany is my "new" pickup, a 1975 Volvo 6X6 303 truck. (BTW, slngsht, why is it that when I try to draft a reply to this thread, I click on the "reply" text box and right away the text box closes and I get a number of full-screen ads for the Brunton Stalker? (Not that I've got anything against the Stalker....) Anybody else have that problem??? Link to comment Share on other sites More sharing options...
slngsht Posted March 4, 2009 Share Posted March 4, 2009 what browser are you using? Link to comment Share on other sites More sharing options...
DB6 Posted March 5, 2009 Share Posted March 5, 2009 they may have heard this is the only car you do not have in your stable, so u r being stalked. PS, can you post a pic of the moggy. Slngsht, Can't help my fascination with odd mechanicals... (Somebody please stop me, before I buy again....!!). In addition to the 'Mog 406 double-cabin, I've got a Land-Rover-based 1990 MWG Esarco 8X8 truck with 4-wheel steering (one of 3 built) and on its way from Germany is my "new" pickup, a 1975 Volvo 6X6 303 truck. (BTW, slngsht, why is it that when I try to draft a reply to this thread, I click on the "reply" text box and right away the text box closes and I get a number of full-screen ads for the Brunton Stalker? (Not that I've got anything against the Stalker....) Anybody else have that problem??? Link to comment Share on other sites More sharing options...
Alaskossie Posted March 5, 2009 Share Posted March 5, 2009 Slngsht, Safari. Everything seems to be working ok now. Link to comment Share on other sites More sharing options...
mebrahimi Posted March 5, 2009 Share Posted March 5, 2009 Slngsht, Safari. Everything seems to be working ok now. Yup, I had introduced a bug when I added the sponsors back in. Link to comment Share on other sites More sharing options...
Alaskossie Posted March 5, 2009 Share Posted March 5, 2009 DB6, Well, you asked for it... attached are photos of the 1990 8X8 Esarco, the 1980 Unimog 406 Doka (former German air force aircraft tug, 22-ton towing capacity!), and the 1975 Volvo 304 6X6 pickup (presently in transit). Can't wait to take a photo of my finished Seven next to (under?) these babies.... Link to comment Share on other sites More sharing options...
DB6 Posted March 5, 2009 Share Posted March 5, 2009 Very cool collection. Link to comment Share on other sites More sharing options...
