throttle + puddle + concrete = :[
hit the back wheels...it looks like lots of positive camber on one side, and about 4 degrees toe on on the other side
bent the frame a bit. i had my deep tread allseason (drifting) tires on the back, and r888s on the front. I'm fine.
probably a good thing to have this minor accident now...I've been getting overly confident with the car >_
Time to do some big repairs before a drifting event saturday!
where is that list of 'things that you must do/that happen while owning a seven'?
it looks like lots of positive camber on one side, and about 4 degrees toe on on the other side .. bent the frame a bit. .. I'm fine.
Man .. I hope you get it together!
Rob
:( Thats bad news but I am sure you can pull it together with a bit of work.
I guess your rear wing proudly labelled "Pussy Magnet" shown in recent pics did not give you enough downforce?:p
hahaha, it wasn't on the car...probably would have saved me too!
That's the problem and joy of these cars. Every one is different.
Good Luck. Glad nobody was hurt.
