Arya Ebrahimi Posted February 23, 2010 Posted February 23, 2010 * (TO THE NON-PROFESSIONALS FROM THE PROFESSIONALS - ALL YOU NEED TO KNOW) **(and I had to learn it the hard way)** *DRILL PRESS:* A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted vertical stabilizer which you had carefully set in the corner where nothing could get to it. *WIRE WHEEL:** * Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh shit...' *ELECTRIC HAND DRILL:* Normally used for spinning pop rivets in their holes until you die of old age. *SKILL SAW:* A portable cutting tool used to make studs too short. *PLIERS:* Used to round off bolt heads. Sometimes used in the creation of blood-blisters. *BELT SANDER:* An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs. *HACKSAW:* One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. *VISE-GRIPS:* Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. *WELDING GLOVES:* Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand. *OXYACETYLENE TORCH:* Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race. *TABLE SAW:* A large stationary power tool commonly used to launch wood projectiles for testing wall integrity. *HYDRAULIC FLOOR JACK:* Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper. *EIGHT-FOOT LONG YELLOW PINE 2X4:* Used for levering an automobile upward off of a trapped hydraulic jack handle. *E-Z OUT BOLT AND STUD EXTRACTOR:* A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use. *BAND SAW:* A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge. *TWO-TON ENGINE HOIST:* A tool for testing the maximum tensile strength of everything you forgot to disconnect. *CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER:* A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle. *AVIATION METAL SNIPS:* See hacksaw. *PHILLIPS SCREWDRIVER:* Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads. *STRAIGHT SCREWDRIVER:* A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws. *PRY BAR:* A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. *HOSE CUTTER:* A tool used to make hoses too short. *HAMMER:** * Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit. *MECHANIC'S KNIFE:* Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines , refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use. *DAMMIT TOOL:* Any handy tool that you grab and throw across the garage while yelling 'DAMMIT! ' at the top of your lungs. It is also, most often, the next tool that you will need. 2
slngsht Posted February 23, 2010 Posted February 23, 2010 see below :leaving: * (TO THE NON-PROFESSIONALS FROM THE PROFESSIONALS - ALL YOU NEED TO KNOW) **(and I had to learn it the hard way)** *DRILL PRESS:* A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted vertical stabilizer which you had carefully set in the corner where nothing could get to it. Done *WIRE WHEEL:** * Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh shit...' Done *ELECTRIC HAND DRILL:* Normally used for spinning pop rivets in their holes until you die of old age. Done *SKILL SAW:* A portable cutting tool used to make studs too short. Done *PLIERS:* Used to round off bolt heads. Sometimes used in the creation of blood-blisters. Done *BELT SANDER:* An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs. Done *HACKSAW:* One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.Done *VISE-GRIPS:* Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. Done *WELDING GLOVES:* Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand. Done *OXYACETYLENE TORCH:* Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race. Done *TABLE SAW:* A large stationary power tool commonly used to launch wood projectiles for testing wall integrity. Done *HYDRAULIC FLOOR JACK:* Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper. Done *EIGHT-FOOT LONG YELLOW PINE 2X4:* Used for levering an automobile upward off of a trapped hydraulic jack handle. not yet, I used to have 2 jacks *E-Z OUT BOLT AND STUD EXTRACTOR:* A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use. Done *BAND SAW:* A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.Done *TWO-TON ENGINE HOIST:* A tool for testing the maximum tensile strength of everything you forgot to disconnect.Done *CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER:* A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.Done *AVIATION METAL SNIPS:* See hacksaw.Done *PHILLIPS SCREWDRIVER:* Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads. Done *STRAIGHT SCREWDRIVER:* A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.Done *PRY BAR:* A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. Done *HOSE CUTTER:* A tool used to make hoses too short. Done *HAMMER:** * Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.Done *MECHANIC'S KNIFE:* Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines , refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.Done *DAMMIT TOOL:* Any handy tool that you grab and throw across the garage while yelling 'DAMMIT! ' at the top of your lungs. It is also, most often, the next tool that you will need.Done Done Done Done
Slonie Posted May 7 Posted May 7 I was seeing if anyone had started some threads on cool handy tools (I'll do that soon) and found this instead. Sure is an oldie but it it's worth a bump! 1
Vovchandr Posted May 8 Posted May 8 Not going funny but rather sincere. The tool for snaps was expensive but made any job on the Cat that required them a breeze Also Thermal infrared (Flir) gun is quite useful for car and home use.
Slonie Posted May 8 Posted May 8 Oh wow that looks handy! That being said, my friend was just installing grommets on a tarp and couldn't use a hammer so he used a plier clamp with the normal tool and ... Seems pretty similar without buying a new tool* *assuming you've done any cabinet work recently and bought that style of clamp The FLIR gun does sound handy as the next step after an IR thermometer. I bought one with the laser pointer AND a contact probe so I could do two jobs with one tool. Very recommended when I was chasing cooling system gremlins.
