* (TO THE NON-PROFESSIONALS FROM THE PROFESSIONALS - ALL YOU NEED TO KNOW)
**(and I had to learn it the hard way)**
*DRILL PRESS:* A tall upright machine useful for suddenly snatching
flat metal bar stock out of your hands so that it smacks you in the
chest and flings your beer across the room, denting the
freshly-painted vertical stabilizer which you had carefully set in the
corner where nothing could get to it.
*WIRE WHEEL:** * Cleans paint off bolts and then throws them somewhere
under the workbench with the speed of light. Also removes fingerprints
and hard-earned calluses from fingers in about the time it takes you
to say, 'Oh shit...'
*ELECTRIC HAND DRILL:* Normally used for spinning pop rivets in their
holes until you die of old age.
*SKILL SAW:* A portable cutting tool used to make studs too short.
*PLIERS:* Used to round off bolt heads. Sometimes used in the creation
of blood-blisters.
*BELT SANDER:* An electric sanding tool commonly used to convert minor
touch-up jobs into major refinishing jobs.
*HACKSAW:* One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
*VISE-GRIPS:* Generally used after pliers to completely round off bolt
heads. If nothing else is available, they can also be used to transfer
intense welding heat to the palm of your hand.
*WELDING GLOVES:* Heavy duty leather gloves used to prolong the
conduction of intense welding heat to the palm of your hand.
*OXYACETYLENE TORCH:* Used almost entirely for lighting various
flammable objects in your shop on fire. Also handy for igniting the
grease inside the wheel hub out of which you want to remove a bearing
race.
*TABLE SAW:* A large stationary power tool commonly used to launch
wood projectiles for testing wall integrity.
*HYDRAULIC FLOOR JACK:* Used for lowering an automobile to the ground
after you have installed your new brake shoes, trapping the jack
handle firmly under the bumper.
*EIGHT-FOOT LONG YELLOW PINE 2X4:* Used for levering an automobile
upward off of a trapped hydraulic jack handle.
*E-Z OUT BOLT AND STUD EXTRACTOR:* A tool ten times harder than any
known drill bit that snaps neatly off in bolt holes thereby ending any
possible future use.
*BAND SAW:* A large stationary power saw primarily used by most shops
to cut good aluminum sheet into smaller pieces that more easily fit
into the trash can after you cut on the inside of the line instead of
the outside edge.
*TWO-TON ENGINE HOIST:* A tool for testing the maximum tensile
strength of everything you forgot to disconnect.
*CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER:* A very large pry bar that
inexplicably has an accurately machined screwdriver tip on the end
opposite the handle.
*AVIATION METAL SNIPS:* See hacksaw.
*PHILLIPS SCREWDRIVER:* Normally used to stab the vacuum seals under
lids or for opening old-style paper-and-tin oil cans and splashing oil
on your shirt; but can also be used, as the name implies, to strip out
Phillips screw heads.
*STRAIGHT SCREWDRIVER:* A tool for opening paint cans. Sometimes used
to convert common slotted screws into non-removable screws.
*PRY BAR:* A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
*HOSE CUTTER:* A tool used to make hoses too short.
*HAMMER:** * Originally employed as a weapon of war, the hammer
nowadays is used as a kind of divining rod to locate the most
expensive parts adjacent the object we are trying to hit.
*MECHANIC'S KNIFE:* Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly
well on contents such as seats, vinyl records, liquids in plastic
bottles, collector magazines , refund checks, and rubber or plastic
parts. Especially useful for slicing work clothes, but only while in
use.
*DAMMIT TOOL:* Any handy tool that you grab and throw across the
garage while yelling 'DAMMIT! ' at the top of your lungs. It is also,
most often, the next tool that you will need.
see below :leaving:
corner where nothing could get to it. Done
to say, 'Oh shit...' Done
holes until you die of old age. Done
*SKILL SAW:* A portable cutting tool used to make studs too short. Done
of blood-blisters. Done
touch-up jobs into major refinishing jobs. Done
dismal your future becomes.Done
intense welding heat to the palm of your hand. Done
conduction of intense welding heat to the palm of your hand. Done
race. Done
wood projectiles for testing wall integrity. Done
handle firmly under the bumper. Done
upward off of a trapped hydraulic jack handle. not yet, I used to have 2 jacks
possible future use. Done
the outside edge.Done
strength of everything you forgot to disconnect.Done
opposite the handle.Done
*AVIATION METAL SNIPS:* See hacksaw.Done
Phillips screw heads. Done
to convert common slotted screws into non-removable screws.Done
bracket you needed to remove in order to replace a 50 cent part. Done
*HOSE CUTTER:* A tool used to make hoses too short. Done
expensive parts adjacent the object we are trying to hit.Done
use.Done
most often, the next tool that you will need.Done
Done
Done
Done
  • 16 years later...
