WestTexasS2K Posted February 5, 2007 Share Posted February 5, 2007 Has anyone seen or know where to buy an air pad that fits the entire seat. Its has baffles alot like a pool float and is about 1" thick. It has a hand pump that you use to fill the seat to the desired pressure. I saw one somewhere and made a mental note. Bad thing is I cant find that mental note. It must be lost with all of those other mental notes. Link to comment Share on other sites More sharing options...
rv-4mike Posted February 6, 2007 Share Posted February 6, 2007 WesT Texas, Cant help you with the air pad. But if you are looking for a way to add some padding to your seat without adding a lot of thickness I highly recommend Temperfoam. It also goes by the names ConforFoam, Astronaut foam and NASA foam. It was designed by NASA for the Apollo program where astronauts were confined to their seats for extended periods. I've made seat cushions for my airplane and glider out of it. My glider seat is 2" thick and I can sit in it comfortably for 9+ hours at a stretch. McMaster Carr and Aircraft Spruce and Specialty carry it as do a number of other sources. Not cheap but worth it. Link to comment Share on other sites More sharing options...
WestTexasS2K Posted February 6, 2007 Author Share Posted February 6, 2007 I had purchased some of that tempter foam from Aircraft spruce and used it last year, but it seams to squash flat after a short while. I am using the 2" pad but in my seat there seems to be alot of weight on the tail bone area and that area seems to be what goes away. Of course nothing may be comfortable for 120 hours of driving. Link to comment Share on other sites More sharing options...
rv-4mike Posted February 6, 2007 Share Posted February 6, 2007 Well never heard of that one before. Sorry it isnt working for you. I wonder if you got a foam of lower density? They are color coded. The ones I've used are green, blue, and pink in order of density with green being the highest. My glider cushion is 1" of green on the bottom with 1" pink on top. The pink crushes, but the green doesnt bottom for me in the glider. The stuff is heat sensitive so maybe its warmer and less dense in the car? In the glider most of my time is spent pretty high at temps in the 20s - 30s. I'd guess that no matter what you use, with the amount of time you are spending in the car you are going to have a sore butt! http://www.usa7s.com/aspnetforum/images/emoticons/ack2.gif Link to comment Share on other sites More sharing options...
JohnCh Posted February 7, 2007 Share Posted February 7, 2007 I made some seat cushions for the USA tour out of a Memory Foam mattress pad. The material works great and is pretty cheap. I purchased a 2" thick King-sized pad from >Overstock for about $75 including shipping. -John Link to comment Share on other sites More sharing options...
manik Posted February 7, 2007 Share Posted February 7, 2007 FYI, the CONFOR foam padding material is made by Aearo: http://www.earsc.com/HOME/products/CushioningMaterials/CONFORFoams/index.asp However, as John pointed out there are many hi-density foam mattress suppliers that can provide custom-cut foam pieces. I'd stay away from the visco elastic 'tempurpedic' type materials and stick with a dense latex foam myself http://www.usa7s.com/aspnetforum/images/emoticons/smile5.gif tm Link to comment Share on other sites More sharing options...
solder_guy Posted February 7, 2007 Share Posted February 7, 2007 I did a few ebay searches and came up with nothing. car lumbar auto lumbar car air seat auto air seat etc, Rob Mitchell Link to comment Share on other sites More sharing options...
Mike Rohaley Posted February 8, 2007 Share Posted February 8, 2007 Sparco sells inserts that can be used, try this link: http://www.sparcousa.com/pseats_acc.asp?id=485 Link to comment Share on other sites More sharing options...
GBOLT Posted January 7, 2009 Share Posted January 7, 2009 Was looking at seating material and came acoss this site if it helps anyone. http://www.aviationsupplyonline.com/category_browse.em?category_id=244006 GB Link to comment Share on other sites More sharing options...
BusaNostra Posted January 7, 2009 Share Posted January 7, 2009 Has anyone seen or know where to buy an air pad that fits the entire seat. Its has baffles alot like a pool float and is about 1" thick. It has a hand pump that you use to fill the seat to the desired pressure. I saw one somewhere and made a mental note. Bad thing is I cant find that mental note. It must be lost with all of those other mental notes. My lotus Esprit V8 has the same system. I think the same thing to the 4cyl Esprit & Elises. Call Jae Lotus talk to the owner Jeff 805-967-5767 The unit part number is 89V6141 called Lumbar support inflatable. if expensive, find a used Elise seat---seen some in ebay, reasonable prices. Link to comment Share on other sites More sharing options...
eVox Posted January 7, 2009 Share Posted January 7, 2009 '80's toyota celica and supra seats (which are 8 way adjustable) came with a pneumatic lumbar support with 3 separate chambers (which can be set individually). Inflation is via a bulb pump similar to those on blood pressure testing cuffs. I plan on adding this system to my kirkey aluminum driving seat. I can post pictures of the parts if you want an idea of how much work it might take. On an related note, in 1984 Car and Driver magazine rated the GTS/Supra driver's seat the best in the business. (http://www.celica-gts.com/mycar/technical_specs.html) Link to comment Share on other sites More sharing options...
WestTexasS2K Posted January 8, 2009 Author Share Posted January 8, 2009 Found a pnuematic lumbar support that has a hand buld to pump it up. They were affordable 35.00 dollars. I got them from Flofit. Link to comment Share on other sites More sharing options...
solder_guy Posted January 8, 2009 Share Posted January 8, 2009 I got them from Flofit. WWW ref?? Rob Link to comment Share on other sites More sharing options...
WestTexasS2K Posted January 9, 2009 Author Share Posted January 9, 2009 It isnt on the website but call them they will have them. http://www.seatsource.com/ Link to comment Share on other sites More sharing options...
