This should fit in a Seven V12
think about how small the sparkplugs are, and the real cooling system, and hardened crank and other parts! THIS is incredible!
Edited by notakit
That is one talented person and one fine work of art.
I wounder how many hours it took to make the complete engine...just amazing.
At the end of the video, I believe "Horas de Trabajos" = Hours of work = 1220
That's 30.5 40-hour weeks :ack:
I didn't think it had spark plugs, I thought it was running on compressed air.
A ton of work for a show piece, but something to be proud of.
"Valve operated 12 cylinder 4-stroke V-engine with two camshafts below, mixed lubrication and air cooling.
21mm bore stroke 21 mm Displacement 87 cm ³ engine capacity of 7.25 cc per cylinder.
Compression ratio of 1:10 weight ca 4800 g speed 950-5000 1/min
Propeller size from 20x10 "up to 24x10"
Length, width, height 350mm --- 160mm --- 140mm
Exhaust opens about 30 degrees crankshaft, bevore bottom dead center
Exhaust closes 10 degrees before top dead center
Inlet opens about 10 degrees before TDC
Intake closes about 30 degrees after bottom dead center
valve overlap approximately 20 degrees
Horsepower approximately 6-8 HP
glowplaqe 4 stroke GRAUPNER
fuel= Methanol,5-10 % Nitromethan and minimum 10% syntetic hi-perfomance-lubrication
camshaft lubrication use ordinary egine oil
For maximum reliability Automatically glow set is recommended.
That is a lot of time an energy but I guess all things of passion are that way.
