MHKflyer52 Posted November 29, 2011 Posted November 29, 2011 That is one talented person and one fine work of art. I wounder how many hours it took to make the complete engine...just amazing.
notakit Posted December 1, 2011 Posted December 1, 2011 (edited) think about how small the sparkplugs are, and the real cooling system, and hardened crank and other parts! THIS is incredible! Edited December 1, 2011 by notakit
scannon Posted December 1, 2011 Posted December 1, 2011 Here's a Ferrari V12 rendered in wood http://media.bestofmicro.com/ferrari-engine-wood-design,Q-6-266622-13.jpg A Ferrari 312 PB in 1:3 scale. Fully functional. Ferrari 312 PB in 1:3 scale
Arya Ebrahimi Posted December 1, 2011 Posted December 1, 2011 That is one talented person and one fine work of art. I wounder how many hours it took to make the complete engine...just amazing. At the end of the video, I believe "Horas de Trabajos" = Hours of work = 1220 That's 30.5 40-hour weeks :ack:
Birkin42 Posted December 2, 2011 Posted December 2, 2011 I didn't think it had spark plugs, I thought it was running on compressed air. A ton of work for a show piece, but something to be proud of.
notakit Posted December 2, 2011 Posted December 2, 2011 "Valve operated 12 cylinder 4-stroke V-engine with two camshafts below, mixed lubrication and air cooling. 21mm bore stroke 21 mm Displacement 87 cm ³ engine capacity of 7.25 cc per cylinder. Compression ratio of 1:10 weight ca 4800 g speed 950-5000 1/min Propeller size from 20x10 "up to 24x10" Length, width, height 350mm --- 160mm --- 140mm Exhaust opens about 30 degrees crankshaft, bevore bottom dead center Exhaust closes 10 degrees before top dead center Inlet opens about 10 degrees before TDC Intake closes about 30 degrees after bottom dead center valve overlap approximately 20 degrees Horsepower approximately 6-8 HP glowplaqe 4 stroke GRAUPNER fuel= Methanol,5-10 % Nitromethan and minimum 10% syntetic hi-perfomance-lubrication camshaft lubrication use ordinary egine oil For maximum reliability Automatically glow set is recommended.
MHKflyer52 Posted December 2, 2011 Posted December 2, 2011 At the end of the video, I believe "Horas de Trabajos" = Hours of work = 1220 That's 30.5 40-hour weeks :ack: That is a lot of time an energy but I guess all things of passion are that way.
