1997 Caterham Seven Classic SE, Registered in New York as Lotus
Aluminum with Red Fiberglass
Close ratio 5 speed transmission
Cosworth 1700cc BDD
Car has less than 4000 miles since construction. Engine is ex Formula Atlantic BDD, constructed with new pistons, rings, bearings, belt, valves, seals, etc. No expense spared in construction of car or engine.
Fil ffina3@aztechtech.com 518-281-8888
caterham_specs.pdf
My opinion on this one is somewhat biased by the fact I'm in the middle of a supersprint 1700 to BDA swap on my s3, but this looks like a great spec for a very nice car. Lots of old school power for an old school car with the added benefit of the most phenomenal soundtrack. Properly balanced, the bottom end should be able to make use of quite a lot of 10500rpm range on the tachometer.
Best of luck with the sale - I hope someone will appreciate the work and money invested in the car and powerplant.
Is it a '91 or a '97? The ad says both. As noted elsewhere, I drove a BDA Cat last year and it felt as fast as my Duratec. I know the butt-0-meter is highly variable, but the power difference over my Supersprint X-flow was shocking.
  • 9 months later...
Would you consider selling the car less engine?
  • 2 months later...
