Hey guys, can someone tell me the distance between mounting points on a Stalker for seats?
I am buying new seats now. I bought a Reverie Mulsanne C seat, it came with sliding rails for a Lotus Elise.
Hey, Manshoon11,
I'll chime in with what little info I can provide. My two cents first . . . FWIW; my seats are hard-mounted (sorry) and do not slide. #85 has two rectangular bars (two per side) welded in between the outer and inner lower frame rails (see photos). Each of my seats are hard-mounted to the forward welded-in bar on for both driver and passenger; the rear bars are for support. The back or my seats are hard-mounted to the upper frame rail of the bulkhead just behind the seat (again, see photo).
One thing I would highly suggest for safety's sake since you are planning on tracking your car (and you may be well ahead of the game, here) is to reinforce your seat mounting points (no mounting to seat rails/tracks/sliders directly to the aluminum skin (floor).
Also, you might send MightyMike a pm. I'm not sure, but his Tillett's may be mounted on sliders.
:cheers:
Edited by xcarguy
I'll probably visit the car this weekend and try a test fit. Although, it will probably be more expensive to go with Lotus Elige mounts, as the Reverie mount for passenger seats is $250 at Sector 111
Alternatively, I can go fixed side mounts for both seats for cheaper.
http://www.reverielimited.com/product_detail.php?prod=black_steel_fixed_seat_subframe_for_all_reverie_seats_black&&subgroup=A SEAT SUB&part_code=R01SI6002
Here they are in a Dax Rush Se7en
:drool:
:drool:
http://www.reverie.ltd.uk/Images/upload/mulsannec_dax_1b.jpg
Looks just like the one I had in my Elise :driving:
I don't know why, but I had it in my mind that your Elise was yellow; I do like the green.
