My Caterham has spacers on all four wheels. They change the Caterham 4 x 4.25" bolt pattern to a 4 x 100mm Miata pattern and compensate for the difference in offset between the Caterham and Miata wheels. No problems in about 15k miles.
I run them when using my autox wheels. If you do use spacers, make sure you are getting the lug nuts at least 8 to 10 threads onto the lugs. Otherwise change out your studs for longer ones.
I found that when you first torque new spacers and lugs down to 100 ft lbs., they will loosen up and need to be re torqued after a bit of use. They seem to require a little settling in time.
Gale
