FE07 Posted September 1, 2014 Share Posted September 1, 2014 Just installed a new speedo (GPS enabled by Speedhut) and now my horn does not work. Worked fine even while doing the install of the speedo. All connections tight, fuse fine and when I short out the wires behind the switch, the horn works. Is there anything else that could be wrong other than the switch? Awfully coincidental? Any suggestions for where to get a horn switch? If anyones interested in the speedo let me know and I'll post more info. Jim Link to comment Share on other sites More sharing options...
jevs Posted September 1, 2014 Share Posted September 1, 2014 Just installed a new speedo (GPS enabled by Speedhut) and now my horn does not work. Worked fine even while doing the install of the speedo. All connections tight, fuse fine and when I short out the wires behind the switch, the horn works. Is there anything else that could be wrong other than the switch? Awfully coincidental? Any suggestions for where to get a horn switch? If anyones interested in the speedo let me know and I'll post more info. Jim If you short the wires at the switch and it works, then it is the switch. Link to comment Share on other sites More sharing options...
My Seven Posted September 1, 2014 Share Posted September 1, 2014 You need to check the horn relay and the horn fuse. Robert Link to comment Share on other sites More sharing options...
xcarguy Posted September 1, 2014 Share Posted September 1, 2014 The horn wouldn't work if he relay was bad. Ditto on a bad switch. Link to comment Share on other sites More sharing options...
Blokko Posted September 1, 2014 Share Posted September 1, 2014 A Caterham part here (realising that may well not have a Caterham, but it would do the trick) - http://caterhamparts.co.uk/product.php?id_product=232 In the UK you could find something similar at a Radio Shack type place - presume it is the same in the US. I had the above on my last Caterham, but I had a habit of missing the button when I needed to go for it quickly. So I took a leaf out of the Westfield book and went for a flash toggle switch instead - http://caterhamparts.co.uk/product.php?id_product=233 I can say without hesitation that it was a very worthwhile 'upgrade' - I'm sure it saved my car from getting hit on at least two occasions. http://caterhamparts.co.uk/img/p/232-232-large.jpg http://caterhamparts.co.uk/img/p/233-233-large.jpg Link to comment Share on other sites More sharing options...
