WTB: sump setup for s2k engine
RGTorque
Take a look at how low the bottom of the bell housing is and you will see that a dry sump doesn't buy you much more ground clearance. A good skid plate that has a bit of hard rubber sheet between it and the pan bottom may be a really cheap alternative for auto crossing. That said a dry sump is really good insurance against oil starvation with slicks on any long corner.
