Hettric
    Norwell MA
  1. I have bumpers for a S3 Caterham that was registered in CT.
  2. Hi, Congratulations on the car. Can you give a run down on registering in MA? It appears things have changed for the better since I registered mine. Is it emission exempt? Thanks
  3. I use a washer of the right radius to fit the groove.
  4. bump
  5. bump
  6. Recently bought a pair of mirrors from Brightonuk, there are pictures on his post of 7/15/20 on this thread. Have decided to go a different direction so they are offered at $38 including shipping.
  7. Does anyone have feedback on or experience with this product? Seems an ideal solution. Thanks
  8. Don't forget eBay UK, got mine there.
  9. PM sent
  10. Don't know if this helps; In 2012 I bought a Caterham from CT that was registered with a CT issued VIN# in 1998 so it was possible then. It's also the same VIN # used currently registered in MA. It had bumpers that were required there (as the only change) but I did not need here. When I looked into the CT process at the time it seemed straightforward compared to what I faced here. You might search this site, I think someone else registered a Caterham in CT not too long ago, they expressed an interest in the bumpers I removed. Good luck Eric
  11. Any new idea's to deal with this? I have the Seven wide mirror and the top on. During the day no problem but when the sun gets low it's blinding. I searched the forum for idea's but any pictures can't be seen. Thanks
  12. Sent PM
  13. Guess I'm confused about "Custom garage hitch ball mount included", thought it had something to do with the ball coupler at the frame front. That must be acting as the tilt latch?
  14. Do you remove the whole tongue to use the "garage trailer"?
