MudHut
Everything posted by MudHut
  1. If it's like mine, the pedal assembly is adjustable for height. I'm 6'1"/225. There is no adjustment for girth. I believe my seat is 18" wide. J
  2. Beautiful car. The whole thing being painted makes in have a very big visual presence. Mine, with the stainless bottom panel and fenders looks a bit incomplete. Wishing your family well. Jay
  3. I've searched for pictures of the car to check out what wheels you have mounted, care to enlighten me? An opportunity to post a bunch of pictures before it changes hands? sizes and specs too?
  4. That looks like a lot of fun. Wasn't recent though, was it? Snow and all? Jay
  5. Don't have your parts, but would be interested in seeing what you are doing. J
  6. I would love to find something that looks like a Panasport in a 17" wheel. 5x100 @ 17x8 and 17x9 would be a great size with varying offsets.
  7. this fitment calculator is pretty simple, but gets the idea across. http://www.willtheyfit.com/index.php?width=225&aspect=45&diameter=17&wheelwidth=8&offset=40&width2=245&aspect2=40&diameter2=17&wheelwidth2=9.5&offset2=30&Submit=Submit
  8. Digging this thread up from the grave of past posts. Most of these posts delve into the ratio and not the Limited slip portion of the rear. I've got a 4.44 VLSD and I believe it is at the end of it's usable life. Can anyone elaborate on the failure MO of the Subaru viscious limited slip differenial? Jay
  9. Roman and Dave, you guys are killing me with this talk of binding and especially of pulling the transmission. It's not a lack of know-how, it's the 'I don't want to, what a pain in the ass' part that is getting me. My pedal is very linear, and take-up and release are fine. Suspect there is no other way to troubleshoot what you guys are eluding to without tearing into it. I may resize the clutch master cylinder first. Ugh, Jay
  10. Very iconic!
  11. More than one owner? I don't question how well built, the great bones are apparent. Jay
  12. Not trying to disparage, but this car visually looks like the builder didn't have a focus on what the end product should be. I think I would spend some time removing extraneous stickers, lights, badges and do-dads, finding a more streamlined idea or look. Reminds me of a retiree's old Ford truck that the owner got hold of a JCWhitney catalog. Not trying to be too critical, just an observation. Jay
  13. simple and ingenious trailer design.
  14. I'm running NT01's in the same size you mention. The Nitto's will probably will heat cycle out and become hard before they wear out considering the cars weight. They tend to get sticky when run hard but that's not a bad thing I suppose, although they sling rocks into the cabin. I haven't had them get greasy feeling like Hoosiers when hot, hot. I'm running 600/500 lb springs so a lower air pressure works well on mine. Nitto's aren't too pricey and are my current favorite. Jay
  15. Thank you for all the replies. I have gotten used to the weight of the clutch because it doesn't require very much pedal travel to disengage and engage. I'm only reminded whenever someone sits in the car and comments on it. It would make for a more pleasurable experience if I could get it a bit easier to depress. I'm going to figure out the factory specifications on the S2000 transmission slave and clutch and contact wildwood about what I currently have and what would work a bit better. I will update the post. Jay
  16. I cannot find the thread that talks about how to remedy the very stiff clutch pedal in the ultralites. Something about bore size on the wildwood setup. Can anyone direct me to the thread or supply some information? Jay
  17. You can borrow one of my license plates. I don't run one on the front. It should be fine. J
  18. I received this for my birthday earlier this month. Cool build, disappointed in the complexity, (doesn't steer, no calipers) although they got the look spot on. Jay
  19. Hi Will, Great to learn you bought a seven. Look forward to seeing you out with the Blue Ridge Region SCCA. Jay
  20. Very first autocross in this car. Helpful comments are welcome. My competition in this region is a fully tricked out Honda CRX on very wide slicks. Missed beating him in this maiden, choppy, bad placement, can't decide a gear, not looking ahead run by .3 sec. A driving comparison from the FF Dulon from last year. Same lot. Jay
  21. I'll trade you cowls, although mine has a bit of damage in the nose. I'd rather not have the door, or, I think I'd rather not have the door. It looks kind of kludged together compared to the rest of the build. Factory height S2000 shifter I suspect. Different knob.
  22. http://www.usa7s.net/vb/showthread.php?10617-WCM-Ultralite-S2k Had my first autocross outing. Superfun.
  23. Follow up: The Bassett 15"x 10" wheels with a 5" backspace work well on the car, do not make contact or rub and are square and can be swapped front to back. http://i356.photobucket.com/albums/oo1/JHogan/Super%20Seven/IMG_3837_zpsoff5bf2v.jpg Jay Hogan
  24. Haven't had any problems with these yet. Thanks for sharing info. Jay
