Davemk1
Everything posted by Davemk1
  1. The state of our infrastructure here in the sates show how well our low tax is working. Bridges falling down and roads falling apart and no plans financially to pay for them. Our politicians don't have the coconuts to tell us we need to pay for the stuff we use as they are afraid they won't get elected (a just fear IMO). So we hold prices low and we get by cheap in the short term. But someone will pay eventually. Who will it be? dave
  2. Tires first for autocross. The LSD won't mean squat if the tires won't hook up anyway. I use Hoosiers (25B) slicks mounted on 13" wheels they will absolutey make you faster. Once you have these and you have gotten good enough you'll want a LSD but until then it might be money misplaced. Just my 2 cents. Dave
  3. I hear you. FWIW I paid about $1200 for the Quaiffe for my Birkin and only paid about $225 for the Phantom Grip I put in the Mazda. The Quaiffe is the only thing I personally know about that will fit the Birkin. Will the Kaaz. Never heard of a Kaaz. Dave
  4. I installed one in a 1976 Mazda RX3. Installation was simple and straight forward and it worked pretty well. I don't think it works as well as a true limited slip but it was much better than the open diff. I used the car for autocross and before installing the Phantom grip it had pretty bad wheel spin in corners and afterward it had much less. I still had to be smart with the throttle but it was much better. I changed the diff oil a few times after installing and it came out looking pretty metallic with lots of suspended stuff. I changed it a few times and it eventually came out clear. I suspect it was bedding in. I frankly didn't care how it affected the diff in the long run as the car was a race only car seeing little mileage.........that and I paid $600 for the whole car so I had little at risk. I sold the car later that year to a friend and he kept it for two year before selling it an the diff seemed fine. That's all I got. Dave
  5. I'd buy mine new as a kit and build it right the first time instead of rebuilding everything. Other than that I'd still get a Birkin. Great car. Dave
  6. That car could make me write bad checks. Dave
  7. Annealed maybe Dave
  8. I wonder what is left on that car that is worth anything? Looking at the photos you can see that one of the front suspension springs got hot enough that it softened and sagged. If it was that hot outside the engine compartment it's hard to believe that the chassis didn't twist too. If the chassis is twisted I should think that the only thing of value is the rear end. I'm surprised the price has gotten as high as it has. The BIN is out of sight. Scary stuff. Dave
  9. We have a local guy who has a few hundred cars (no exaggeration) in his yard. You know the type.........cars everywhere. A good friend went to this guys place to buy an old Europa from him. The seller wanted to prove that it ran well so went to start the car for the buyer. The buyer still had his money in his pocket when the seller got the car running. They smelled something and looked to see a fuel line leaking onto the exhaust. Before they could do anything the car was fully engulfed and burned to the ground. A wad of burned fiberglass and metal. My friend the seller was pretty happy that he still had his money in his pocket. That old Europa is still there. The would be no way to tell what it is....or was. Bummer, Dave
  10. Looks like our cars are cousins..........mine is #1009. Dave
  11. I believe my Birkin was built near that same time. What's your chassis number? Dave
  12. Very good point about the ferrules on the housing ends. They make the housing seat well and take out slop as well as providing a seal to crap getting in. Dave
  13. My car has a Zetec and the overflow bottle is right below the pedal box almost under the steering shaft. seem fine and never really thought of it. Dave
  14. Any quality bike cable and housing should be fine. Most cable is made by the same company and then sold under a number of different names. If you want to be 100% sure you've got good stuff get Shimano............that's always a safe bet. Dave
  15. That is more or less how my Birkin is set up. The inner cable is fixed and the housing floats. You are right that the housing rubs against the pedal box hole it passes through but mine has a delrin guide that keeps it from binding or abrading the housing. It helps to make sure that the first half of the cable run from the pedal is clear an also the the cable to move naturally when you push the pedal. Mine didn't work that well until I replaced the cable and housing. Being in the bicycle biz I naturally used bike cables for the job. They work much, much better than the crap Birkin cable. I used an inner cable that has a teflon covering and an outer housing that has a teflon lining and there is now much bette throttle control as you can make very small movements with little to no stiction. It also takes less effort to push down the pedal and it returns all the way very quickly. If you want to get extra fancy you can use bike gear cable and housing. The cable is about the same as brake cable but the housing is a good bit different. Most housing is like the stuff on the Birkin...........it's a coiled wire with a rubber coating over the outside. The coiled wire compresses a good bit under pressure and can give the cable action a good bit of slop. Gear cable on the other hand uses metal but it's not coiled. Gear housing uses small metal rods running lengthwise and arranged on a circle to make a tube. This tube is then lined with teflon and covered with plastic on the outside. This in done on bicycles to give very precise shifting. It also works very well as throttle cable for the same reason. The housing doesn't compress. Good stuff. Dave
  16. Good deal. I love my Birkin and bet you will love yours too. Dave
  17. As much as I love living here and can't imagine ever leaving it does have it down sides. I say this so that folks considering having the meet in this area can keep this in mind. Driving for sport over some of the roads here in the summer can be a frustrating deal. The Beartooth has to be one of the coolest roads on the planet but during the summer (as long as school is out) there is a good bit of traffic and it goes slow. Folks are taking in the views. I've driven over the Beartooth a few times but never in my Seven for sport fun. It was a bit frustrating even in my VW station-wagon due to the motor-homes and the such. I imagine that if one were to drive it at first light it might be much better but keep in mind that the pass goes over 10,000 feet and it will be cold up there in the AM. Near freezing wouldn't surprise me in the slightest. Something similar in Yellowstone proper. During the summer it's just plain crowded. Not so much that you can't have fun sight seeing but if you want to drive for fun it might not be that much fun. The east-west route across the northern section of the park (lamar river valley) would be the best bet and spits you out of the park into Cooke City and later Cody if you like. This section has the least amount of traffic/tourist and could be fun early in the AM. Kit Kat has it right that there are many long straight stretches of road. It is very open here and if it's hot or it's windy then you'll be hot and blown around. Most areas have little or no shelter. There are very few tree lined back roads that will protect you in an open car. I can promise no shade and at altitude the sun is strong and hot. When you get away from these tourist areas there will be no one. The population density is bizarrely low. With all the election hub bub recently it was pointed out to me that the state of New Hampshire has a higher population than Montana does. This combined with an east-west border to border distance that is about the same as Chicago to DC means that there is no one here. The folks are are in in the summer all go to a few spots and all drive Motor-homes with Apache written on the sides. With careful planning routes could be picked that have fun twisty roads mixed with long straight open sections that will have near zero traffic. Just keep and eye out for wildlife on the roads and you'll have fun. Anyway..........I feel like I'm trying to talk folks out of coming here and that is far from the truth. I write the above so folks know what they can expect and plan accordingly. I just pictured us all stopped atop the Beartooth highway and getting lots of dirty look from folks who thought it would be empty. Thanks for reading. Dave Bozeman MT
  18. Nice to see people are interested in seeing MT. I like it here. The photo is taken from my home office window here in Bozeman. Another day in hell. Dave http://www.serotta.com/forum/attachment.php?attachmentid=35475&stc=1
  19. I agree that hoping for any real downforce is silly. I realize I'm splitting hairs here with the wording but I can picture reducing lift a bit and making the car a bit more slippery with the removal of the windshield, a front splitter under the nose-cone, a tray under the rear axle and a diffuser. Seems like those things could add up to make a small difference overall. Thoughts? Dave
  20. I'm looking for added performance in autocross. Since most autocross speeds are pretty low in the big scheme of things I'm not sure how much advantage there is to be had. I guess my main goal would be to add downforce. I think the easiest way to reduce overall drag is to remove the windshield and that's pretty simple. I'm not sure how it is on other Sevens but on the Birkin the area under and around the rear axle is open and the rear rises at too steep and angle to function as a diffuser. So my rough idea is to make a panel that will fill in the area around the axle as best possible and to make/buy a diffuser for the rear under the tank that doesn't rise as quickly and would better manage the air flow. Thoughts? Dave
  21. I'm thinking that I might want to make some changes to my Birkin to help in the aerodynamics dept. I was thinking a front splitter and a rear diffuser. Designing and making the splitter seems pretty simple. I'm less confident about the rear diffuser design. Anyone out there in Seven-ville know anything about this or know of anything available? Thanks, Dave
  22. A Seven could never be in the biz.....Seven's give more than they promise not promise more than they give. Dave
  23. Davemk1
    ebay car
    Anyone know this car? Dave http://cgi.ebay.com/ebaymotors/1969-Lotus-Seven-SS-Mk7-400-hp-Turbo-13B-Rotary-TEC-2_W0QQitemZ200180604575QQcmdZViewItem?hash=item200180604575 http://www.rpmengineering.com/20071206/7/IMG_1673.jpg
  24. I don't know what the easiest way is but this way seems pretty easy. I used string pulled across the sides of the rear wheels pulled forward past the fronts. The rear track is wider than the front so you can pull the string right past the fronts. Then measure from the string in to the front wheel. On my Birkin the rear end was twisted. I installed Woody's trailing arm kit and they are adjustable so I was able to adjust the length of the arms and get the rear axle perpendicular to the chassis center line and parallel to the front axle centerline. After I did mine I noticed that the rear just felt more stable at highway speeds. Not a day and night difference but it's nice to know it's right. If you are careful and take your time you get very consistent, repeatable results. I hope that makes sense and helps. Dave
  25. Did you ay you checked the rear thrust angle? Dave
