Thanks for the warm welcome. I was able to contact the daughter/co-driver of the car based on the SCCA stickers on the car. She confirmed that they are the original owners and the same gentleman that built the car for them has been maintaining it over the years. It was registered for street use in California properly as a 07 Caterham with BAR exemption under SB-100 so it is smog exempt here but they very rarely drove it on the road, it was mostly trailered to/from Qualcomm Stadium where they ran it in SCCA autocross. Unfortunately her father is not well and they are getting rid of some of their cars. The gentleman I purchased the car from got it as a package deal along with a Corvette they had been collecting.
Overall I think I got very lucky with the condition of the car, it’s at a local race shop getting a few things done:
Rear differential, I will post pictures but looks good
we replaced the rear diff fluid as preventative maintenance
replaced brake/clutch fluid and engine oil
new valve cover gasket
plugs look good
compression test good
coolant and gear oil both look new
replaced lugnuts as the ones fitted were too large (19mm bulge vs 17mm)
replaced intake coupler with a better fitting one, the old one was making contact with the idler pulley and had a small hole worn in it.
all suspension and heim joints nice and tight
brake pads have 9-10mm all around
Monday morning they will try to connect to the MBE ecu, not sure if they will be able to since we don’t have any CAN adapter for it, are these the older serial connectors or CAN type?
they will run it on the dyno as a final health check for peace of mind.
at some point I will want to replace the following:
harness
revert to original intake manifold setup
tires (205/50/15 & 225/45/15 Toyo R888 currently fitted). might try the Avon ZZS in 195/50/15 & 245/40/15 unless anyone has better suggestion?
