Yellow Birkin S3 built in 2008, constantly updated, well sorted, easy to drive, RELIABLE, 2 liter Zetec, T9 5 speed transmission. The car runs great and is a blast to drive. Selling for $26K
For Massachusetts Super 7 enthusiasts this properly and fully registered in Mass which is a big plus. I can educate you on the very painful and extensive process. This is much easier than buying one out of state or registering a new kit of any make.
Odometer now shows 7800 miles, 1400 put on during my ownership.
Drive Train/Engine Package includes:
Firmware update for ECU and tuning made the engine start instantly and run strong.
2016 Dyno show 160 BHP at crank; power is more than adequate and to be respected.
Raceline water rail, Stewart Manufacturing electric water pump and controller, electric fan.
East Coast Alternator 6 pound 2025 UltraMini 55 amp installed 2018.
2 Ford reprogrammed ECUs, 2 PCM and ignition modules included.
Engine believed to be Series 3 because it has aluminum and steel sump, offset water pump, and horizontal oil filter.
T9 standard ratio transmission flushed and fresh Redline gear lube 2020
2 quart Accusump with electric pressure sensing valve.
Quaife limited slip 3.91 ratio
Chassis:
Wide track front end, installed by previous owner in Spring of 2019, has all new A-arms, ball joints, stub axles, steering arms, brake rotors and 4 piston Wilwood calipers, Wilwood .75” brake master cylinders, fender stays, working fenders and new front fenders. The new front end is quick and easy to align (street and track alignments now practical) and improves handling with 2” wider track than original.
Jaz 15 position, single adjustable coil over shocks, corner weighted for 190 lb driver and half tank of gas.
Other Information:
Shortened fiberglass seats, reinforced driver's seat, OEM upholstered and light weight aluminum rear interior panels, 3 point belts installed, 5 or 6 point driver belts included, Hella battery cut off switch.
Shown with 2019 Bridgestone 195-50-15 RE71R tires on Black Enkei RPF1s with Black 948 Racing wheels Extra 4 silver Enkei RPF1 wheels with 2015 195-50-15 Dunlop Direzza Sport ZII Star Spec tires.
Tall (broomstick test) 5 point track day roll bar has removable SFI padded Petty bar included.
Complete canvas package with is in good to fair condition. Tonneau cover needs a one new zipper. The rest is fully functional.
Caterham clear and Birkin tinted wind wings.
Driveshaft safety hoops.
Braided stainless DOT approved brake lines, braided fuel and oil pressure gauge and Accusump lines.
New Lightweight stainless steel Magnaflow side exit 2.5 inch muffler with universal catalytic convertor
New OEM 11 gallon tank with a new external Walbro GSL393 Inline Fuel Pump 155LPH .
New 15lb Braille battery installed March 2022
More Photos will be provided upon request
