First here's a shot of what the bracket looks like. This is one of the early brackets, which is different than what most of you probably have:
http://www.usa7s.com/forum/uploads/slngsht/pict0236.jpg
The dimension measured below is from the top bolt of the clutch flange, to the sheet metal. it is the same dimension from the top bolt of either master cylinder as well. With my new cylinders, this is too high - The hood doesn't shut properly.
http://www.usa7s.com/forum/uploads/slngsht/pict0234.jpg
Also, as you see below, the push rods are completely out of alignment, and that's probably b/c the pedal was cut and shortened at some point.
http://www.usa7s.com/forum/uploads/slngsht/pict0235.jpg
http://www.usa7s.com/forum/uploads/slngsht/pict0237.jpg
Anyway, I can make a new bracket, but I'm wondering if the later style brackets locate the master cylinder at a lower position. If so, I will try to get one through Dennis.
