empti
Everything posted by empti
  1. I am wondering, how much louder it is after the decat pipe? I am thinking about it.
  2. The 420R factory mirror is flat, and it's very hard to see any vehicle on the side. I am wondering what type of rearview mirror do you use on a road car (the one with windshield)? Any recommendations? Do you mount it to the door, or on the side of the windshield?
  3. Looking for the 420R Sport Suspension (coilovers) . I currently have "Track Suspension" but I think the spring is a bit too stiff for road use.
  4. The leak was very noticeable, I had a stream of oil on my garage floor after parking it overnight. I think the vibration caused the washer to move a bit and that explained why it didn't leak that much during my assembly process.
  5. Yes, but it's not the right size.
  6. I ran in to the same problem. The left is the OE bolt & washer, the right (M10x1.25) bolt and washer were from Amazon. Let's hope it resolves the issue.
  7. Sounds good. Thanks!
  8. Thanks! I'll refit the seat later. I am 5'7" so I can only barely reach the pedals. If the seat can be adjusted more forward I will not try to adjust the pedals.
  9. @Nocturnal005 @KnifeySpoony I am wondering how far back/forth your seats can slide? I noticed mine can probably can only slide 2 inches forward from all the way back. Is this the case on yours ?
  10. I think recent shipments all came with 888Rs. Mine has 888R as well.
  11. @Geowiz Here is how I did it. In my case the pre-drilled hole for the control cable is on the left side of the steering column. I think the air box mounting bolts have spacers and may allow the cable to tuck underneath it. I'll update you once I have reached that far into the build. Before/After:
  12. How many flat top Esco jackstands do I need for Caterham? 3 or 4? Thanks!
  13. @hahuang65 My 420R is probably shipped within the same container as yours. I need to upgrade the garage lighting before the kit arrives. PM sent to you as well. Maybe we can share some idea building it.
  14. @JimmyG You mentioned that the carbon seats are fixed to the floor? Do you know if the seat can fit the slider? Thanks!
  15. Thanks for showing me your 420R last weekend. It was such unfortunate that this happened.
