Origin7
Everything posted by Origin7
  1. Sunday morning, wheels off cleaning.
  2. Getting kids around cars and giving them something to be passionate about is such a gift. Those small moments can have a profound impact. I went for my first ride in a Caterham when I was seven years old, and looking back, that experience probably played a big role in motivating me to pursue an engineering degree. My capstone project was a stress and strain analysis of a Locost chassis. Now, decades later, I’ve been fortunate enough to buy the very same car I first rode in as a seven-year-old. Today, my own kids (seven-year-old twins) absolutely love riding in it.
  3. Thanks for the offer, Dan. I may be in touch.
  4. Updated post to include roll cage.
  5. From my non-automotive/industrial experience, if these sensors have an LED they typically pulse ON/OFF when triggered. If you're sure a metal object is passing through the viewing area, and you're getting nothing out, it's toast.
  6. I'm not certain, but I think engine OFF, ignition ON is legal in most states.
  7. I leave my ignition ON and watch the gauge as I fill. When I hit full, I stop. I probably don't quite get it as full as I can, but no mishaps yet.
  8. Thanks @JohnCh It’s nice to hear about PET. I work in the industry and actually tried developing a recycled PET filament about a decade ago. It didn’t gain much traction at the time, so it’s great to hear it’s being used now. It’s a good material and readily available. I’ve also been experimenting with high-durometer TPU in the engine bay. I’ll report back on how that goes.
  9. There is some good real estate under the steering column that I decided to put to good use. I used some brass heat-set inserts for threads. For everything outside the engine bay, I use PETG with carbon fiber. I highly recommend it. This area is a perfect fit for an Element Extinguisher. I realize these aren't as good as a bottle of novec 1230, but it will probably be sufficient for my needs.
  10. @hahuang65 I am not sure how easy it would be from underneath, but if you can get the length, width, and height, you can calculate the approximate volume. Gallons = (LxWxH)/231
  11. Curious why you'd remove the regulator. If the mechanical pump is maintaining 2-3 psi, maybe there is no benefit?
  12. Can you get some rough measurements and calculate the capacity (roughly)? Then you know if you can only put 5 gallons in a 10 gallon tank, you have a problem. I am not exactly sure what that problem would be, but it's a starting point.
  13. Great article and photography!
  14. @IamScotticus fingers crossed. I'd rather be than wrenching at the moment.
  15. That sounds quite manageable, and much easier than taking the head off. Looks like I'll be going after this as soon as the seals come in from Burton. Hopefully, they are the right ones
  16. Has anyone replaced the valve seals with the head on? Trying to gain a better understanding of what's involved.
  17. @IamScotticus All good points. Thank you for the feedback. I am with you 100% on the catch can. I've got one on the way. Also, I may eliminate the heater/hoses. I'd like to use that space for other things.
  18. I am new to this, so feel free to critique my approach or tell me if anything here seems incorrect. I tried increasing the advance at idle, but the engine didn't seem to like it. It showed the obvious signs of too much advance. Long story short, I went back to the timing curve shown above. It's also worth noting that I confirmed with a timing gun that the timing value and RPM at idle matched what the engine was actually doing. This was just to confirm that the 123 system was set up properly. With a reasonable baseline timing curve, I then jumped into the carbs. The shop set me up with 28mm chokes, 55f8 idle jets, f16 emission tubes, and 120 main jets. Idle mixture screws were set 2.5 turns out. The emulsion tubes and mains jets matched what @JohnCh kindly sent me for the factory setup. The shop insisted 28mm chokes and larger jets were a better setup than the Caterham factory setup . The plug color and the way the car was running indicated this was not the case (way too rich). So, I installed 32mm chokes and 45f9 idle jets. I also changed out the idle mixture screws, which showed some signs of overtightening or corrosion (maybe both) on the needle portion. I backed out the idle mixture screws 1.5 turns and fired it up. I adjusted the idle mixture screws per the procedure. Next, I adjusted the idle speed, then synchronized. Long story short, the engine is running much better. It idles more smoothly, no spitting back through the carbs, little to no smoke, and pulls through the mid RPM range really well. I have to say, setting the idle mixture screws is a bit difficult. I think I need to work on this more. I do get some hesitation/bogging when I am driving and crack the throttle from low rpm. It's not terrible, but I hope to eliminate this. My understanding is that this could be caused by being either too rich or too lean with the idle screws. I like @NSXguy's recommendation to add a wide-band O2 sensor. For someone just starting out tuning carbs, I think it would be nice to see the result of the changes I am making. This may be the next step for me. Anyway, I'd welcome anyone's feedback, especially on getting the idle mixture screws set well. I am definitely in the ballpark, but shooting for perfection .
  19. I'm working on establishing a good, safe baseline ignition curve before I start working on the carb setup. I am getting a lot of smoke after idling for a bit, so it seems like it needs to be advanced at idle. Hoping to do a quick sanity check here. Here is my current setup: This is what I am considering - Fewer plotted points, adding advance at idle, and all in at 3k. Look about right as a starting point? RPM Advance 500 12° 1000 16° 1500 22° 2200 28° 3000 32° 4000 32°
  20. I’m looking for a roll bar (update: or roll cage) for an ’89 Super Sprint (imperial, De Dion). Ideally, something in the New England area so I can pick it up. I’m after something taller and more substantial than what I currently have. Preferably, a bar that’s better suited for track days. It doesn’t need to be a perfect bolt-in. As long as the geometry is close, I can handle any modifications needed to make it work. If you have anything that might fit the bill, please let me know. For reference, here’s what I’m currently running. It doesn’t exactly inspire confidence.
  21. This is a valid point.
  22. Thanks! That's a great idea. Much easier than remodeling it in various sizes.
  23. I needed a plug for the port in the firewall that allows you to access the speedo cable connection. I designed this with a flange in the back to keep out moisture. When printed out of flexible TPU, it pops right in. File attached. Feel free to use, share, and modify. Speedo_Plug_Rev1.STEP
  24. Thanks @CBuff. Great feedback. I like the idea of the bedliner under the seats. Seems like the perfect solution. I just carpeted under my seats (because that's what was originally there). That probably makes me even more of a polishing queen.
