The mystery V8 7 project is mine,the frame is 4 inches longer,4 inches wider and 2 inches taller,sort of like a Mcsorley but a little differant,the frame is made out of 1 1/2 0.83 square tubing,it has an SCCA legal roll cage made out of 1 1/2 dom 0.95 round tubing,mustang 2 front spindles,chrysler ball joints,custom lower contol arms,adjustable upper control arms,heavy duty hiem joints,pinto rack and pinion,heim joint tie rod ends,with adjustable bump steer,borgsan steering ujoints,ball bearing steering colum,removable steering,wheel,wilwood mastercylindeers,adjustable brake bias,2003 mustang cobra brakes,13 inch front rotors 2 piston front calipers.11.65 rear rotors,calipers with parking brake,4 link rear suspention with panard rod,4 mustang bullet wheels 17 x 10.5 rear,17 x 9.5 front,double pass custom radiator,electric fan,8.8 rear axel with 3.23 posi also 3.55 gear set,t5 transmision plus several other t5s and parts,.8 over drive gear set for t5,stock 5.0 ford v8,now for the engine,306 ci DDS short block,bilett crank,billet cap screw rods,forged flat top pistons,level 20 dds heat treated block,bored,decked,line bored,balanced,dds stud girgle with main studs,190 cc aluminiam heads 2.02/1.60 stainles steel valves,10 degree locks and retainers,screw in studs and stud girdle,crane roller rockers,ford motorsport x-303 cam,custom 8 quart oilpan,pump and pickup,aluminiam flywheel,hurst shifter,msd igniton box,autometer and vdo gauges,2 road race seats,2 rear fenders that need to be widened because the tires are so big,nose cone that needs to be widened,rci fuel cell,plus tons of othe parts that I forget
I have lost interest in thus project and want to sell it call me at 540-207-2042 any time thanks Dave
