leeper
Everything posted by leeper
Here was the advertisement that sold me... This was in 2009 83 Donkervoort For Sale Hello, and thank you for your interest in my 1983 Donkervoort for sale. I bought this car a little over 4 years ago. The car has been a ton of fun. I have not driven it nearly as much as I would have liked to in the last 4 years. Which is why I am selling it. When I bought the car I was a single man, now I am married with children and the time is just not there. I believe this year I might have driven it 4 times and cars like this need to be driven. Some facts about the car. I am the third owner of the car. The guy I bought it from had just finished a complete rebuild of the car. He is a very skilled individual with aluminum as you can see from the picture. The work on the side draft air intake and the air exhaust in the aluminum nose cone was all done by hand. He decided to not use the clamshell fenders when he rebuilt the car but instead tried to make it look a little more modern. I do have the original clamshell front fenders and the original fiberglass nose cone that is black. The front fenders have been the biggest problem on the car. The brackets are from something else that were modified. So there is a weld on the bracket where the fender meets the bracket that often gives. Since I live in the Denver area I am lucky to know Ben at Caterham USA. I just had the car up there to have some work done on it. We looked at putting a set of Caterham fenders on it. The Caterham fenders are a little narrower, but would look very good. It wouldn’t be that hard to make the fit. The cost would be around 500.00. I had Ben fix the plumbing on the clutch. Prior there were alot of junctions’ in the line and it was leaking. Thankfully the whole car is aluminum so it was not a big deal, but some of the brake fluid did drip into the floor board of the driver side and got on the powder coated frame and took the paint off. As I mentioned Ben fixed it up nicely and cleaned up the plumbing and put in a new master cylinder. What he did looks awesome with the steel braded lines. When I bought the car I got it from a guy in Detroit Michigan. As I mentioned he had just finished restoring it and had put about 500 miles on the car. When he got the car it only had 3000 miles on it. When I picked it up I came back to Denver CO. via St Louis so I could attend the Log 25. I was a great way to pick up a car. When heading back from St Louis to Denver right about the Colorado, Kansas border the speedometer quite working. Turn’s out there is a right angle drive that comes out of the transmission that had broke. I took the right angle drive to a local speedometer shop and attempted to have it fixed but to no luck. Just this year I ended up putting a VDO speedometer with a magnetic pickup instead of trying to mess with the original one. I just completed this install this summer so the millage on the car is hard to tell for sure. If I had to guess it is well below 6,000 miles and probably below 4,000 miles. regret not fixing this sooner, but getting time to work on the car has always been a problem for me. So since the first owner only drove it 3K miles that means it has probably traveled more miles on a trailer then on a road. When I picked up the car I had a fellow member from the Lotus club with me in a rental car as an insurance policy to get the car home. Not only were we able to get the original clamsheel fenders and nose cone, but I also have boxes and crates of parts. I also have several binders of documentation on the car. I am hoping who ever buys the car is able to take all this history with it. I had the top and a back window made for the car. I have the original full weather cover, but the prior owner told me it won’t fit anymore because of the roll bar. I also had a case made for the doors to keep them from getting scratched up in the back. I am not extremely knowledgeable about all the in’s and out of the engine. But this is what the prior owner listed about it and I have never messed with the engine. Big Value Lotus Twin Cam, rebuild with “fast Road” cams and twin Dellorto carbs. Only the block and the connecting rods where not replaced in the rebuild. Cortina 4 – speed semi-close ration gearbox. Cortina 3.77 rear axle. As mentioned the engine is a lotus twin cam, and yes it does leak oil. I have never had it looked at, I am just told that is a lotus twin cam. I just had the carbs rebuilt this year and it is running better then ever. I live near Denver so that is around 5500 ft of elevation. So depending on where you live you might have to have the carbs re-jetted. I am asking XXXXXXXX for the car. I will accept bank wire, cash or a combination. If you want to do a cashiers check it will need to clear my bank for 7 days before the car leaves. Please feel free to call or email if you have any questions.
Well here we are again... Some 6+ years ago I purchased this gem through this site and I've loved the the car dearly but it is time for a new chapter. I will post more later but needed to get this first step out of the way. Asking $25K but for the right owner I'll work with you as the previous owner did with me. Currently the car is in Alexandria VA and in good working order! Thanks, Calvin
Keep posting guys! If you are doing this and it's open, I'll try to figure out the logistics and join you. I'm up in Alexandria but I'd be up for a nice ride and love that stretch of road. Calvin Per Lee 83 Donkervoort S7
I've got Delortos and I think it would be pretty straight forward though the previous owner swore that it was all black magic. A couple weeks ago I ran it out of gas (first time for that) and it hasn't run right since. I've reseated the plugs, they seem to be fine. I checked airflow and fuel flow and whatever it is, is beyond my limited knowledge. I needed to find a good shop in the local area anyway, guess this is as good an excuse as any. Not going to even attempt 495 which is the suggested route, so I'll have some fun on the surface streets! Thanks!
I recently moved to Alexandria and I need my carburators balanced. I found a shop "Motörhead Limited" and I'm wondering if anyone here has experience with them.
That is not what he meant but that is a great solution!
Was just given a suggestion to use magnets from a coworker. I explained that both the plate and the nOse are aluminum so now he is searching for an aluminum magnet!
Recently moved to Northern VA and I'm now required to have a front license plate. As I have an aluminum nose, I really don't want to drill holes in it. Anyone have any creative yet legal ideas?
Getting really close! Should be able to pick up the car this week! http://usa7s.com/vb/picture.php?albumid=37&pictureid=298 Anybody have experience negotiating with the insurance company for the degradation in value due to the frame damage?
hope other states follow this example
leeper replied to slngsht's topic in Politics, Religion and Controversy
As a Gov Employee, I agree! I do support the bill though, but again I'm bias in that I have a high clearance which mandates drug testing in addition to random polygraph. I agree because I believe that Government employees should be held to a higher standard. Once upon a time "made to government standards" used to mean something... Now its thought of as "made by the lowest bidder." For those not employed... I'd have to see the metrics after a couple quarters. Does the end justify the means? It sounds good in principal but at $35 a pop, does it actually fix a problem? -
Odd, the pics in post 1 will not show on my phone but are just fine on the laptop. If I've done it wrong, please let me know and I'll repost.
Thought you guys might enjoy this. Here is the villain, missing an 8 inch piece of plastic! The plastic was found right next to my smashed sunglasses. http://usa7s.com/vb/picture.php?albumid=37&pictureid=259
They charged him with failing to slow down and the neck and upper back were pretty sore for a few days but all of the x-rays came back clean. At first I actually felt sorry for the guy. Remember I mentioned my wife was standing right there... She ripped into the guy for quite awhile and I was trying to calm her down. Later I found out that he was texting and I wish I had let her pummel him. I was trying to think of a better way to signal that I'm stopping or turning (leds that are currently on there are pretty small) but I don't think anything short of not driving would have avoided this accident. Bare aluminum makes it pretty difficult to say that they didn't see me and it's not like the car is subtle in any other way.
As I was pulling into subdivision from highway, I see the wife and 9 mo daughter waiting for my son's school bus to drop him off. Slow down to make the turn but the guy behind me was busy texting so he and his Murano slammed into me hard enough to make my sunglasses fly (he ran over those too), and give the family quite a scare. There are concrete storm drains on both sides of the street so if I actually had the wheel turned at all, I would have ended up in one of them with a lot more damage.
Not exactly a fair fight but the Donkervoort took it well and will fight another day. http://www.usa7s.net/vb/picture.php?albumid=37&pictureid=258 http://www.usa7s.net/vb/picture.php?albumid=37&pictureid=257 The insurance company has been awesome and basically wrote a blank check to get it fixed and I definitely found the right body guy. http://www.usa7s.net/vb/picture.php?albumid=37&pictureid=256 http://www.usa7s.net/vb/picture.php?albumid=37&pictureid=255 He's been working on it for about a week now and all damage has been removed. Now it's time to re-skin!
Seven Grill, Seven Heat Shield and other custom parts
leeper replied to solder_guy's topic in General Sevens Discussion
bump for Martin. -
You already are and have always been paying for those who don't. This is a control measure and I have little doubt that even the greatest supporters of government run healthcare would and do choke at some of the content in the current plan. But here's the thing. No one that has all of the information can deny the inability sustain our current path. With that in mind, let's solve the problem or at least work towards a solution. Standing back and just saying no just leaves the problem for future generations. There will always be people out there trying to abuse the system and the amount of resources that you would expend to stop it would make the war on drugs look like an effective plan. Mitigate, adapt and remember that there is always more than a single option but if you never try to make your surroundings better (even if it's just for you, yours and what you come in contact with) then why are you here? BTW - pluralism is not the ability to say no in multiple languages.
