Everything posted by Ross
WTB Rear Fenders Caterham /Birkin/Locost Style WIDE
Ross replied to Bonjo2's topic in Parts For Sale / Wanted
Recently replaced green fiber glass fenders and nose cone with carbon fiber. Rear fenders have holes drilled for fender guards. Have installed fender guards on the carbon fiber. which I am using....will sell as a set or just the rear fenders. Bob Virginia Beach 757 463-4904 -
I have a black set that came with Caterham....not perfect. replaced them with chrome set. 757 463-4904 Bob Virginia Beach
A new Birkin with annular clutch slave should/will have equal performance as compared to the external slave cylinder. The problem may be in the selection of clutch assembly or type of disc. In the past few years I have successfully installed annular cluch assemblies in a Lotus 7 and a TVR. Once properly installed, no problem. Bob 05 Caterham 69 TVR
good news. Can you wrap it up so no damage to frame and glass occurrs? I do have a paypal account. what is your preference for payment? please respond to
Have been driving an 05 Caterham with an air deflector....Brooklands would be an improvement...would like to purchase the assy. 757 619-9393 Bob
Good modification...thanks for your article. which item? Part number, manufacturer on Amazon.com? Dont see a filler cap bung in any of the adds? Bob
Thanks for the comments...did more testing (driving)....is slipping when aggressive throttle applied in lower gears...will pull the trans & engine as a unit since I' d like to replace clutch cable with hydraulics. Bob
Clutch slips in 5th gear at 4k to 5k RPM.....have no slippage in lower gears. To repair is it necessary to pull engine and transmission as a unit or can you disconnect and drop transmission from bottom (05 Caterham Dedion classic)? Bob
Due to inability to set this tach I bought a new one....oops. After providing a ground to the tach the new one works....am selling original (programable) Caterham tach. $50. Bob
Received new tach, same PN from Caterham....when installed it ran up past 8,000 RPM and pegged. After laboriously checking all connections & wires, ignition and coil out put found nothing wrong.....further looking at back of the original tach that came with the car, I noticed at the switching settings a "very small" hole with an indented arrow...made an adjustment and read correctly, problem solved. Previous owner must have used it this way for years. BTW a new repacement tach (Caterham) has no adjustments on the back other than replacing a lite bulb. Bob
Thanks for your comments....as pulse is coming out from coil, a bench tach registers correct engine RPM, then must be a problem with the tach. Have ordered a replacement tach,# 71261. Anxious to see if that will solve the problem. Bob Caterham S3 +8 Morgan TVR Vixen
Recently accquired Caterham 05, Tach registers double the actual value...Tach experts (Noisonger) advised, if working, may be ok, check installation. Unit (electronic ignition)appears only inside distributor, no points, just a small black box sitting where the points used to be.....which manufacture or type is the best for this set up? There are no external electrical units installed with this ignition. I have checked rear of tach and ran thru all the available setting options, no difference. The manufacturer identification is not readily apparent....an option would be to replace it with a new and improved electronic ignition, any suggestions? Bob
Recently acquired an 05 Caterham S3....it came with a new uninstalled tonneau which measures 68" width x 43" length....have ordered the correct one for the Seven. $200 or best offer...... Bob © 757 619-9393
The 05 Caterham that I bought came with a tonneau and boot cover. the boot fits perfectly...tonneau is too wide and too long, would need drastic cutting to make it work. Any one have an S3 tonneau that needs a new home? also don't need the one I have..
What is the acceptable oil pressure at idle? Under acceleration pressure will go up to 40 lbs. Will idle down to 20 lbs and/or 15lbs. Have installed a safety cut off switch on the oil pressure line......at a longer than usually idling situation it will occassionally cut off the electric fuel pump. Recall questioning engine builder, Abacus Racing, they didn't seem too concerned. Any opinions/suggestions? Bob
Integral Remote Type 4 speed semi-close ratio transmission with steel bell housing. Used in 67 Cortina, Lotus Seven. Ratios: 2.97; 2.01; 1.39; 1.00 Rebuilt by Abacus Racing, Virginia Beach, in excess of $1,500. With throw out bearing, lever and clutch slave. $500. Bob 757 463-4904 Virginia Beach, Virginia.
Good job Folis...brings back memories with the Potomac Porsche Club Bob
Send info to thanks
Need a minilite type wheel for a spare, to match what is on the Caterham. Performance Alloy Superlite wheel made in Australia (4.21 offset). Original supplier in Australia has one, however shippping is almost $200.....found a set of 4 at $300, however they don't want to just sell one. Any one have this or a similar wheel?
Am planning on running with the wind deflector....will see how it goes...finally waiting for delivery of Caterham! Bob 05 Caterham Morgan +8 TVR Vixen
I plan on giving it a try. Have had many motorcycles, BMW for the past 25 years....am the buyer of Scotts Caterham..looking forward to its arrival! Bob Ross M3 BMW Morgan +8 TVR Vixen MGB F800GS R75/5
In 1999 I purchased a 63 Lotus Super Seven from Canada.....Arrangements were made to ship to Virgina using TFX International, Vehicle Transport Canada/USA. They took care of customs and the associated paperwork. It arrived in an enclosed 18 wheel truck. No problems.. was expensive....
Integral remote Ford/Cortina semi close 4 spd: 2.97; 2.01; 1.39; 1.00 rebuilt/refurbished, with steel bell housing by Abacus Racing Virginia Beach, Virginia $850. 757 463-4904 Also have a spare Ford Xflow. $300.
How sad, one must constantly evaluate the traffic situation around them. I do not see evidence of a 5 point seat restraint. A single lap belt now seems inappropriate.....my condolences to the family.
