jevs Posted June 8, 2015 Posted June 8, 2015 (edited) I am thinking of adding a thin padded piece on top of the tunnel that will be removable separate from the tunnel. It would also have the boot and trim ring for the hand brake. This will allow me to open up the area of the tunnel that slides over the hand brake more and also provide a little comfort cushion for the arm. Curious if anyone else has done this and if there are pictures? I would like to do it in a way that there are no screws or fasteners on top, but I have a couple ideas for that. I may also let it go just a little over the edge of the tunnel panel to hide the seem where the tunnel and shifter panel meet. Edited June 8, 2015 by jevs
toedrag Posted June 8, 2015 Posted June 8, 2015 Found this on #47, http://www471.pair.com/stalkerv/gallery2/main.php?g2_itemId=3834 : http://www471.pair.com/stalkerv/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=3834&g2_serialNumber=2
paulshark Posted June 12, 2015 Posted June 12, 2015 Nice try! ________________ [TABLE=width: 241] [TR] [TD=class: xl83, width: 241]Paul e Shark Spaccio[/TD] [/TR] [/TABLE]
Bonjo2 Posted June 25, 2015 Posted June 25, 2015 I used some cheap speaker carpet, and some reflective insulation. It fits under the dash in front of the shifter and between seats and tunnel. My shift boot pops on top and it stays put. I added a small bit of yoga mat in the elbow area.
toedrag Posted June 25, 2015 Posted June 25, 2015 You know, after driving mine for a few miles, I find it's the inward-facing edge of the side panel that bothers me. I keep rubbing my elbow on it. I haven't noticed the tunnel top or edge at all. I'm considering using either some sort of corner guard or corner molding, or something u-shaped to fit over the top of the sides that would cover the exposed edge of the aluminum.
xcarguy Posted June 26, 2015 Posted June 26, 2015 You know, after driving mine for a few miles, I find it's the inward-facing edge of the side panel that bothers me. I keep rubbing my elbow on it. It may mean bending new panels, but here is what I did originally on #85.
MightyMike Posted June 26, 2015 Posted June 26, 2015 Perhaps you could velcro a small cushion on top of a solid surface... http://i57.tinypic.com/2vv3new.jpg http://i62.tinypic.com/os4phi.jpg
jevs Posted June 26, 2015 Author Posted June 26, 2015 I have all the materials to make mine. I just have another project to get done first.....the car is on hold for a few weeks.
