newtoit Posted August 29, 2015 Share Posted August 29, 2015 Rebuilt engine.. What is the firing sequence on the distributor? Link to comment Share on other sites More sharing options...
Nick OTeen Posted August 29, 2015 Share Posted August 29, 2015 You didn't specify which Cosworth engine but it is probably 1 - 3 - 4 - 2. Link to comment Share on other sites More sharing options...
newtoit Posted August 29, 2015 Author Share Posted August 29, 2015 You didn't specify which Cosworth engine but it is probably 1 - 3 - 4 - 2. 116e engine . Problem is cylinders 1 and 4 not firing. Link to comment Share on other sites More sharing options...
coffee break Posted August 30, 2015 Share Posted August 30, 2015 2 coil packs? Link to comment Share on other sites More sharing options...
Nick OTeen Posted August 30, 2015 Share Posted August 30, 2015 116e engine . Problem is cylinders 1 and 4 not firing.Any backfiring when trying to get it started? Check and make sure you haven't crossed up the plug wires on 1 and 4. Link to comment Share on other sites More sharing options...
Ian7 Posted August 31, 2015 Share Posted August 31, 2015 Also, its not just whether the wires on the cap are in the correct positions. There are typically 11 drive teeth on the distributor drive gear, and therefore 10 ways to get it wrong when you install it into the block.... Link to comment Share on other sites More sharing options...
newtoit Posted August 31, 2015 Author Share Posted August 31, 2015 Also, its not just whether the wires on the cap are in the correct positions. There are typically 11 drive teeth on the distributor drive gear, and therefore 10 ways to get it wrong when you install it into the block.... got it, crossed wires. How about fine tuning the timing? Cannot find any info on timing marks. Any clue? Valve clearences also Link to comment Share on other sites More sharing options...
