coffee break Posted December 28, 2015 Share Posted December 28, 2015 I have a red light on the dash that will come on when I first start the car and then go off after a minute or less. Any RPM over idle would make it go off. Recently, it has come on at lower RPM and go off at higher speeds. What is the light telling me? Link to comment Share on other sites More sharing options...
locost7018 Posted December 28, 2015 Share Posted December 28, 2015 On my locost it is the alternator light. On when just started and off after the rpm goes up. It came on solid when I lost a wire on the alternator. Russ Link to comment Share on other sites More sharing options...
NVP66S Posted December 28, 2015 Share Posted December 28, 2015 (edited) If it is the alternator light (which I do not know on your specific car), the operation is pretty simple, once explained. One side of the light is tied to the battery (+) and the other side to the regulator output. When the engine is not turning, the light is on because the regulator side is LOW and the battery side is HIGH. At some low RPM, the alternator puts out enough voltage to nearly match the battery HIGH, so the light goes out. If the alternator slowly fails, this voltage is reached at a higher engine speed, so the light stays on longer. The other possibility is that it's the oil pressure light. Does your car have an oil pressure gauge? Dan Edited December 28, 2015 by NVP66S more info Link to comment Share on other sites More sharing options...
coffee break Posted December 28, 2015 Author Share Posted December 28, 2015 The other possibility is that it's the oil pressure light. Does your car have an oil pressure gauge? Dan The car has a gauge and it is indicating good pressure. Thanks for the descripting of the alternator system. Link to comment Share on other sites More sharing options...
TheDingo8MyBaby Posted December 28, 2015 Share Posted December 28, 2015 According to the caterham manual: Battery charging – RED The light illuminates as a bulb check when the ignition switch is turned to position ‘II’ and extinguishes as soon as the engine is running. If it remains on, or illuminates whilst driving, a fault with the battery charging system is indicated. Seek qualified assistance. A few things to check: -grounds/connections to the alternator -belt tightness -voltage regulator on your alternator As long as the light is off most of the time, it may not be an issue, though it could mean you're due for an alternator soon. -Geoff Link to comment Share on other sites More sharing options...
NVP66S Posted December 28, 2015 Share Posted December 28, 2015 (edited) According to the caterham manual: A few things to check: -grounds/connections to the alternator -belt tightness -voltage regulator on your alternator As long as the light is off most of the time, it may not be an issue, though it could mean you're due for an alternator soon. -Geoff[/quote Yup. Or a voltage regulator. I recently replaced one of those in my wife's 300D. The brushes were worn down. It cost $36 instead of $180 for a rebuilt Bosch alternator (which includes the regulator). If it were the belt tension, you'd probably hear a screetch. Dan Edited December 28, 2015 by NVP66S Link to comment Share on other sites More sharing options...
coffee break Posted January 11, 2016 Author Share Posted January 11, 2016 I removed the alternator and took it to SHR Auto Electric (Sleepy Hollow Rebuilders). It was determined that the regulator was the problem. It turned out that the alternator is a relatively common item and they had a new unit on the shelf. It's installed and no red light and 13.8v at idle. Link to comment Share on other sites More sharing options...
coffee break Posted March 28, 2016 Author Share Posted March 28, 2016 The Red Light is giving me a message but I'm not sure what is wrong. Since I installed a new alternator the red light stays off at idle but, now it flickers at the same RPM as the engine stumble that has started. Between 4 and 5k the motor goes flat and I happen to look at the light and it was flickering. ??????? I'm thinking about putting a volt meter somewhere to look for voltage drop but it's a guess. Link to comment Share on other sites More sharing options...
scannon Posted March 28, 2016 Share Posted March 28, 2016 Check and clean all your grounding points. Make sure you have a ground cable to the chassis as well as directly to the engine. Link to comment Share on other sites More sharing options...
coffee break Posted April 19, 2016 Author Share Posted April 19, 2016 Check and clean all your grounding points. Make sure you have a ground cable to the chassis as well as directly to the engine. Skip, Crappy electrical connections were the problem. Voltage to the coil was dropping as RPM increased, 7v @4k and 3v @5k. My mechanic cleaned up the connections and it revs great. Link to comment Share on other sites More sharing options...
