so, with info from MichaelD i got a car cover off ebay
http://www.ebay.com/itm/Lotus-Seven-57-72-Caterham-Fitted-Outdoor-Car-Cover-SALE-/200582992462?hash=item2eb3ad924e:m:mTTZO6L8fBKXFStxNg0STig&vxp=mtr
cover is VERY nice. it fits my ultralite VERY snug... i would have it be a inch bigger in length and a hair lower (i have 18" wheels) otherwise not change a thing.
pardon the mess in the shop, i had a shelf brake and everything is on the floor until i put my new on up.
pics of this cover on MichaelD's car can be found here http://www.usa7s.net/vb/showthread.php?10381-Seven-Car-Cover&highlight=car+cover
http://i.imgur.com/785oQfcl.jpg
http://i.imgur.com/2QIBl2nl.jpg
http://i.imgur.com/ty7KnRPl.jpg
Nice. Can't tell abt yours, but my cover has a strap midway that fastens and tightens underneath and holds the cover in place.
mine has the straps as well. but its on so snug that i cant imagine any wind removing the cover... even what we had last year over the 4th at njmp.
Mike,
This cover does as well. I have had two other covers in the past. Both were overly large and difficult to manage. This one is almost perfect even with the full cage. I would use the straps if I kept the car outside any length of time. Currently I only use it over night at the track.
Keep in mind that this cover is actually made for a Caterham Seven so it is form fit. Other Sevens may have a slightly different shape.
Edited by MichaelD
"Keep in mind that this cover is actually made for a Caterham Seven so it is form fit. Other Sevens may have a slightly different shape."
Caged Super stalkers are probably out of the question then, huh? I sent my dimensions to the vendor but haven't heard back yet.
i find the cover is a bit loose on top but around the fenders its a bit... tight. really depends on your footprint or fender overhang i think.
Shoe String,
Sen the dimensions to me and I will check them against my car/cage w clamshells while I am working on it this weekend.
Shoe String,
great. here they are:
My Brunton Superstalker is
overall length 10-10
width at front and rear fenders: 5-4
rear hoop: 46" high & 40.5 wide at top
front hoop; 42" high, and 34.5" ahead of rear hoop
mirrors are 31" high and and extend to 5-2 overall width ( inside fenders width)
wheel base is 7-7
pics here: https://www.dropbox.com/sh/fgedpfk5044ozpa/AADbc-7FYdlYB3q0_lsUVcFoa?dl=0
Thanks.
My Caterham S3 Dimensions inchec
Wheelbase 87.6
Track/tread (front) 52.6
Track/tread (rear) 52.6
Length 122
Width front 62
Width rear 62
Height bonnet 31.5
Cage width front 38
Cage width rear 37
Cage rear height 44.5
Cage front height 44.5
Ground clearance 3.1
Weight 1188 dry
Thanks Michael, looks to me that the critical dimensions are
overall length SS = +8"
rear hoop height SS = +1.5"
rear hoop width SS = +3.5"
Would you think there's enough room in your cover to accommodate that additional SS volume?
Thanks for the help.
Ted,
I am in the midst pulling the motor and trans. Once I get them out I will put the nose and bonnet back on along with a few boards on the cage to make it a little taller and wider. Then I can see how much stretch is left. Even if it is on jack stands.
You are looking for +3.5" in width and 1" taller cage with +8" in length, Correct? Who cares about the sides as long as the rain can't get in the seating area :-)
if you guys want i can lend you my cover for a test fit as long as you dont keep it to long. i only use it inside. just pay for the shipping to you and back to me...
