bball7754 Posted July 29, 2016 Share Posted July 29, 2016 This isn't for my Seven, but it is for a Crossflow - on my Mallock. I've had a small coolant leak somewhere around the thermostat housing. Since that portion of the engine is exposed, the coolant gets pushed around everywhere. I pulled the housing off (it also has a swirl pot attached) and there was quite a bit of corrosion and what seemed like poor gasket and sealant. Do you think a new gasket and sealant will seal correctly? Link to comment Share on other sites More sharing options...
mrmustang Posted July 29, 2016 Share Posted July 29, 2016 Do you think a new gasket and sealant will seal correctly? Any chance you have, or no someone with a fixed base belt sander that you could use to smooth that surface a bit? if it was me, I would not use that without at least a quick sand down. Maybe bring it to a metal working shop if you have to Link to comment Share on other sites More sharing options...
rx7locost Posted July 29, 2016 Share Posted July 29, 2016 (edited) I'd sandblast the surface to clean out the rust. Then use a small amount of JB Weld to fill the pits. And sand flat using a sheet of sandpaper on a pane of glass (with a bit of water under the sandpaper). That should show a combination of the base metal and the JB. Edited July 29, 2016 by rx7locost Link to comment Share on other sites More sharing options...
bball7754 Posted July 29, 2016 Author Share Posted July 29, 2016 Thanks, that's what I thought but have been in denial. Called an engine machine shop today and asked if they could mill it flat and remove the corrosion. Said it was too small to do that. I think they just weren't interested in such a small job. Guess I'll try some other shops. Link to comment Share on other sites More sharing options...
MightyMike Posted July 29, 2016 Share Posted July 29, 2016 I'd sandblast the surface to clean out the rust. Then use a small amount of JB Weld to fill the pits. And sand flat using a sheet of sandpaper on a pane of glass (with a bit of water under the sandpaper). That should show a combination of the base metal and the JB. +1 - that'll work. Link to comment Share on other sites More sharing options...
scannon Posted July 29, 2016 Share Posted July 29, 2016 As bad as that part looks inside I think you need to do some serious cooling system flushing. If the water jackets have that much rust on them heat transfer is going to be badly affected. Link to comment Share on other sites More sharing options...
NVP66S Posted July 29, 2016 Share Posted July 29, 2016 Don't know what the machine shops would charge, but you can buy that belt sander for 80 bucks. http://www.harborfreight.com/4-inch-x-36-inch-belt-6-inch-disc-sander-97181.html and at the end you will still have the tool. Link to comment Share on other sites More sharing options...
