hairball29 Posted November 30, 2017 Posted November 30, 2017 Hi, all This is the ongoing issue I've mentioned in the hard starting thread, and a few others, but I wanted to share what's up in case anyone who's good at electrics can help. It's confusing the hell out of me, but I'm no auto electrician. The headline is that when I connect my AF gauge or something like a USB socket in the manner described in the diagram, it seems to upset the ECU and the car won't start. From measuring and logging, the RPM data disappears from the logs using my SCT device, and the Fuel pump driver module stops sending 8v to the pump, as normally commanded by the ECU. The problem comes when the AF is powered and the earth is in any way connected to the chassis earth. As soon as I disconnect the device, the car starts and runs well. The rewiring I've done to see what happens is You'll see from the diagram that the wiring is about as simple as it gets. +ve from the battery, -ve from the chassis but this setup results in no start. If i run an earth from the battery to the earth bolt (in diagram) or even directly to the AF gauge negative wire - no start if i get a spare battery and connect - and + to the gauge with the O2 sensor connected - no start Connect a spare battery to the AF gauge and DISCONNECT the O2 sensor - START Connect the car's battery to the AF and DISCONNECT the O2 sensor - START So... to me it seems like an earth issue, but I don't know what or how to test. I can tell that the ECU's case is earthed, that the engine, chassis and battery have very low resistance between any of them. The Battery to engine wire is new, the battery is new, but now I'm stuck. I don't have a wiring diagram and without taking out the dash and un-bundling the loom, i can't easily trace wires. I do have the Focus green book which shows me ECU pins and their connections. If anyone has any thoughts on what's going on here, I'd love to hear them! Otherwise the car is great. It goes like a scolded cat and has made me into a minor celebrity in the neighborhood Thanks in advance http://www.usa7s.net/vb/attachment.php?attachmentid=13616&stc=1
JPS Europa Posted November 30, 2017 Posted November 30, 2017 I don't think you can say that the exhaust system is at ground potential. What with gaskets and rubber hangars and all... What brand gauge and sensor? Forgetting starting for a moment, does the A/F read (full lean since the car is not running) and does the O2 sensor get hot? In your scenario above, its not really clear that you COMPLETELY disconnected the A/F from the car electrics when you did your battery test. You are clearly making the ECU unhappy. Time to look for voltage drops. How is your ECU grounded?
hairball29 Posted November 30, 2017 Author Posted November 30, 2017 Hi, It's an AEM 30-4110 UEGO gauge. You're right about the exhaust, but all i can tell you is that the resistance between the pipe and the battery -ve is 00.2 ohms on my multimeter, that's basically the same as between the battery and chassis, or battery and engine. The above diagram shows how it's usually wired. In other tests, I have disconnected the wires from the car, + and -, then run new temporary wires to the gauge to ensure they're separate. It'll start if i do that AND the O2 sensor is unplugged from the gauge. If the sensor is plugged in, we're back to no start. The 02 does get hot when it's plugged in. The ECU appears to be grounded through its plug, and the ECU case seems also to be ground. I can't easily see where the plug wires then go as they're all bound up and I have no diagram, so I'm hoping someone knows of tests I can do such as the voltage drop you mention. From speaking to others, I hear that a big enough drop will upset the ECU, but that was in the context of a bad starter pulling lots of current. When i read the battery voltage during cranking, it goes from 12.3 down to 10 and a bit. Then back up to 13.4 ish when running. With the AF connected, it does the same, except it won't start. Thanks
Larry Smith Posted November 30, 2017 Posted November 30, 2017 Hi, you might find this link helpfull https://www.americanmuscle.com/autometer-airfuel-install.html
Larry Smith Posted November 30, 2017 Posted November 30, 2017 here is another link https://www.carid.com/images/sunpro/custom-gauges/pdf/cp7011-installation-instructions.pdf
JPS Europa Posted December 1, 2017 Posted December 1, 2017 Here is another thought or 2. Is your O2 sensor 3 wire or 4 wire? I am guessing 3. My stuff is all 4, but I do recall seeing a ring with a wire under it for a 3 wire which went off to ground on a car which I was working on. That ground is typically for sensor ground, not the heater. I know that sounds bass ackwards, but that is what I have seen. Heater ground is back through the controller...in your case the gauge. Two of my cars run Megasquirt. At 10 volts the ECU gets sleepy and the cars wont start. Here is another experiment. Start your car, then plug in the O2 sensor once already started. Does it keep running?
JohnCh Posted December 1, 2017 Posted December 1, 2017 or something like a USB socket in the manner described in the diagram, it seems to upset the ECU and the car won't start. Can you expand on the above? The current conversation is centered around the WBO2 set up, but this indicates that might be a red herring. What USB setup creates the same issue? Thanks, John
hairball29 Posted December 1, 2017 Author Posted December 1, 2017 Hi, all thanks for the input. The 02 sensor has a 6 core cable that plugs in one end at the gauge, and terminates at the O2 sensor JohnCh, i just went out to test again. When i first started working on this, i just had a cigarette lighter socket with a dual USB plug in it which seemed to break it. Just now i tested and that seems to not be the case now. At least today! this is what i found: - Cigarette lighter with USB plug connected to my phone and charging (so drawing current from the battery) and wired in using the same connections as the AF above - start - AF gauge plugged in as above NOT connected to O2 - Start - AF gauge plugged in as above and connected to O2 - NO start So, it seems that the car will withstand a small amount of juice being drawn through the battery and back into the chassis, such as the USB charger, but perhaps when the O2 sensor heater draw is added, the no-start comes back. now, i should say that it failed to start pretty consistently before with just the USB plugged in, but i couldn't consistently recreate that just now. there were a couple of non-starts Do you think it's possible that the extra draw from the AF is lowering the voltage too much for the ECU to stand? I thought stock ECUs could stand a drop to below 10v? does anyone know what their battery drops to when cranking?
JPS Europa Posted December 1, 2017 Posted December 1, 2017 That is exactly what I am thinking. My battery drops less than a volt when cranking with my Seven and Europa...never bothered to check any of the other cars. Did you get a chance to try start without O2 plugged in then plugging it in while running? That will settle once and for all whether low voltage is your ECU issue as the alternator will keep the voltage up. Did you check voltage at the ECU while cranking? I don't think any of them will run below 9 volts and as I mentioned earlier, I have a couple where its "Game Over" at 10V. Go get em!
JohnCh Posted December 1, 2017 Posted December 1, 2017 Another thing to try -- and someone please correct me if this is a bad idea -- is to jump start the car. Hook up another running vehicle like you would do with a dead battery on the se7en and try to start it. I imagine with the other car running and likely a much larger battery in place, a big voltage hit would be far less likely to occur under these conditions. If it starts easily, you have likely confirmed this is the issue. -John
Larry Smith Posted December 1, 2017 Posted December 1, 2017 As a Retired mechanic,I have found out that must cars wont start if the voltage to the ECU is 10volts or less,also JohnCh idea may be a good try,because your voltage would stay above the 10 volts needed. Larry
hairball29 Posted December 2, 2017 Author Posted December 2, 2017 Hi, guys Typically i start the car by unplugging the AF (connected to the O2), start it, then plug it back to run my AF. I have never had a problem when doing that. it runs great during the plug in, there's no discernible changes to the motor, revs or anything. When i was really struggling with this, i would connect the battery to a jump/charger device which fed it 13.x volts, and a few times the problem would go away. i have not connected it to a running car, so I'll give it a try. I had wondered about jump starting it down a slope with gauge connected, meaning there'd be no starter motor pulling juice, or is that a bad idea? I have to figure out how to measure the voltage into the ECU. i have the pin-out from the focus manual, but i don't have a thin enough probe to get in there whilst it's connected. I have probed it whilst disconnected and it's at 12v fwiw. Could the starter be bad and drawing too much voltage? I have heard that opinion from another Seven person. thanks
coffee break Posted December 2, 2017 Posted December 2, 2017 It sounds like a signal issue not really a voltage problem. In certain connection configurations the ECU outputs make the motor run, but with an additional connection/input to the ECU stops outputting enough signals for operation. Well it's my SWAG, keep trying.
hairball29 Posted December 2, 2017 Author Posted December 2, 2017 Hi, there’s no more inputs or outputs on the ecu when the af is on as it doesn’t connect to the ecu, it’s just the gauge and the sensor powered from the battery
hairball29 Posted December 2, 2017 Author Posted December 2, 2017 Just tried the car-to-car jump and confirmed the connection was bringing in the same voltage as the running donor car. No change. Still won't start and with the same symptoms. Soon as i unplug the AF, problem goes away.
JPS Europa Posted December 3, 2017 Posted December 3, 2017 So if you plug in the O2 sensor...AF gauge otherwise powered up...with the car already running, does the car die? Does the gauge respond properly...does it actually read A/F?
hairball29 Posted December 3, 2017 Author Posted December 3, 2017 Hi, Once the car's running, I can then plug in the AF or O2 or both and all is well. It doesn't upset the running at all, it only makes trouble on startup.
JohnCh Posted December 3, 2017 Posted December 3, 2017 I just did a quick search and found some mentions of the AEM causing issues with ECUs. EMI is suggested as a culprit and there was also a statement that the sensor or timing ground shared with the gauge is a "no-no" No explanation of why though. How close is your ECU to the AEM gauge? If they are close, is it possible to increase that distance temporarily to see if it makes a difference? You mention earlier "From measuring and logging, the RPM data disappears from the logs using my SCT device, and the Fuel pump driver module stops sending 8v to the pump, as normally commanded by the ECU." Perhaps EMI is causing that interruption? -John
breezy7 Posted December 3, 2017 Posted December 3, 2017 (edited) How close is the AF gauge to the PATS transponder? Since it only affects starting I would think it points to the PATS system, according to Ford after the engine is running for 1 second PATS is out of the picture. That may explain why it won't start with the gauge connected but runs fine with it connected once the engine is running. The gauge seems to be the common factor in your problem, I say that assuming when the oxygen sensor is disconnected the gauge is not operating. Are you using a different oxygen sensor then what came with the engine? I think mine was a 3 or 4 wire sensor, maybe a non standard sensor is an issue. Is there a reason for wanting the AF gauge? Is it for tuning reasons? Could you run the AF gauge through a switch ? Disconnect it during start then switch it on once running. It hides the problem but doesn't fix it. Edited December 3, 2017 by breezy7
