papak Posted September 28, 2018 Share Posted September 28, 2018 I picked up a used Subaru R180 LSD diff for my Birkin during construction. It was fairly low mileage (30k). I cleaned it up and resealed the side plates and rear cover. I also replaced the axle seals. Now that I have 1500 miles on the car, I found that both seals a leaking a little. It’s just enough to be a little messy under the diff. I show that this diff takes .8 qts of GL-5. Is this seepage evidence of overservicing or have the seals worn that quickly? I’ve got replacements but it’s a real pain in the ass to change them out if I don’t have to. Link to comment Share on other sites More sharing options...
Ferdl Posted September 28, 2018 Share Posted September 28, 2018 ... I found that both seals a leaking a little. It’s just enough to be a little messy under the diff. Are you sure the axle seals are leaking? I had a leaking axle seal and the oil was thrown away by the rotating axle towards gas tank, trunk and so on. Link to comment Share on other sites More sharing options...
papak Posted September 28, 2018 Author Share Posted September 28, 2018 I show a drop or two sitting inside the flare and a trail down the side a bottom of the housing. All of the seams are dry. It’s not “slinging” it to any extent. I’ll remove the upper plug this afternoon and check the level while I have it up on stands. Link to comment Share on other sites More sharing options...
papak Posted September 28, 2018 Author Share Posted September 28, 2018 I pulled the top plug on the end plate and can't feel fluid with my finger. This doesn't mean too much as the back of the car is jacked up and the clearance between the aluminum end plate and the diff is only about 1 ½". I show the correct fill amount to be .8 qt. I can't recall if this fills to the level of the top plug or not. Any info on this ? Link to comment Share on other sites More sharing options...
papak Posted September 29, 2018 Author Share Posted September 29, 2018 I checked on the a Subie forum and the fill is either 1.1 liters or fill to the bottom of the upper plug. Everyone seems to be an authority. I think I’ll fill to the upper plug and hold off on changing the seals as they aren’t slinging lube. Just a slight seep at this point. Link to comment Share on other sites More sharing options...
wemtd Posted September 29, 2018 Share Posted September 29, 2018 Papak - my notes on this are as follows: Rear differential (Subaru R160 LSD): 2008 Forester XS. Oil capacity: 0.9L of 75/90 synthetic gear oil. IIRC there is a lower drain plug and a second filler/plug above that: fill level should be to bottom of that plug (until oil runs out) on a level surface. But if you checked on an angle... Link to comment Share on other sites More sharing options...
oilteq Posted September 29, 2018 Share Posted September 29, 2018 Synthetic oils often produce less seal swell than petroleum oils. An 80W-90 petroleum oil may dry it up. Link to comment Share on other sites More sharing options...
papak Posted October 1, 2018 Author Share Posted October 1, 2018 I pumped in .3-.4l of Lubrimoly GL-5 75-90 into it yesterday (til it ran out). I then stuck my finger in the upper fill port and pushed a bit out, hopefully to compensate for the angle of the diff while jacked up. My assurances that it was a precisely calibrated finger. Given that it's from a Subaru, I figure that is precise enough. When I did the original installation, I replaced the breather with a -4 hose that vents to the top of the boot. I should have it back on the road later this week (I originally jacked it up to replace an intermittent Facet LP fuel pump). Link to comment Share on other sites More sharing options...
