Can the collective wisdom direct me to a source for headers for this motor? The exhaust exits on the passengers side. Hopefully there's a source for these. The vehicle is a 1986>87 Sabre 7 built on the west coast and is a pretty good replica. All help is appreciated.
Nick
You might try Tom Carlin (tbox56). Tom is the Birkin distributor. He might have a set for a Birkin that could fit.
Worst case contact Simpson exhausts prices are very good they are in the UK but will sort you out
Has them replace my superlite exhaust shiping is a pain but worth it
Nick,
I have an unused 2.3 header, but you would need to fabricate the rest of the exhaust system. I bought it for a front wheel driver project and it never happened. I'm attaching a couple pictures so you can have a look.
I also have a dual side draft intake manifold for the 2.3, but I'm guessing you already have what you need for that.
Dan
Alfonse is right. This header is for a Duratec. It won't fit the 2.3 Lima motor (if that's what you have). If you happen to have the Duratec motor, you're golden. If you decide you want the header, it's $175 plus shipping from 98296.
If you do have the Lima 2.3, look around on some of the Merkur or Pinto/Bobcat forums or http://www.esslingeracing.com/.
