ashyers Posted December 8, 2018 Posted December 8, 2018 Hello All, I was wondering if anyone had the suffix list for the Ford Duratec buckets/lifters/tappets. The main P/N is CP9Z-6500-***. The "***" is a series of 3 letters that correspond to different thicknesses. For example CP9Z-6500-AAB appears to correspond to a 3.000mm bucket. It sure would make ordering them easier if I had that info! Andy
papak Posted December 8, 2018 Posted December 8, 2018 (edited) http://www.usa7s.net/vb/attachment.php?attachmentid=14837&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=14838&stc=1 I think I have it filed away somewhere. I'll post it over the weekend. If you are using the 1.25" aluminum tubing, I can loan you the flaring tool if you would like. It puts a nice ridge in the tube. Edited December 8, 2018 by papak
ashyers Posted December 11, 2018 Author Posted December 11, 2018 papak, I've found that Esslinger stocks buckets for $10/bucket. The local Ford dealer was useless, they didn't even know what I was asking for... I suspect if I could get all of the Ford P/N's I could do better than Esslinger's prices, but they may win out on convenience. I think I'll be purchasing 16+ buckets to get the clearances sorted. Thanks for the offer of the flaring tool, mine just arrived today, along with a pile of other goodies. I'm still not sure if forward progress has been achieved. There's been a few more surprises than I anticipated in this car. Fun, fun, fun! Andy ps. Love the photos of your engine bay! I'll be studying them carefully .
papak Posted December 11, 2018 Posted December 11, 2018 Just think about how much knowledge you are accruing... sometimes it is the process, not the result, that is most enduring.
1turbofocus Posted December 11, 2018 Posted December 11, 2018 I have a couple buckets of these , let me know the size you need .000 ? not the part # thats to hard to read on some Tom
ashyers Posted December 11, 2018 Author Posted December 11, 2018 Tom, Here's the list of what I removed with the old cams ! 3.000 3.202 3.222 (x4) 3.262 3.282 3.322 (x3) 3.362 (x3) 3.382 3.422 A few buckets that definitely not good enough for set up. A 3.222, 3.362, and 3.422 are junk. None of 'em are beautiful! I was planning on purchasing new buckets as I don't want to risk the new cams. If you know any magic on setting this stuff up without spending a mint on buckets I'm all ears! Thanks, Andy
JohnCh Posted December 12, 2018 Posted December 12, 2018 I had to replace some tappets about 6 years ago and discovered it was a lot easier buying them from my local Mazda dealer. Below are the part number conversions from my notes: 3.302: LF01-12-556 3.382: LF01-12-561 3.522: LF01-12-568 3.625: LF01-12-574 3.650: LF01-12-575 3.725: LF01-12-578 -John
1turbofocus Posted December 18, 2018 Posted December 18, 2018 To me easy and cheap way to set up the Cam clearances is DO NOT cut the valve tips when doing the Valve Job , When you cut the seats and the valve seats you raise the valve up twords the cam , this will make 90-95% of your clearances to tight , cut the valve stem as needed and use that to set clearances , you can also move the buckets around to help keep from buying more , Make sense ? Tom
ashyers Posted December 19, 2018 Author Posted December 19, 2018 Tom, Thanks for the advice. I have a set of buckets on the way in the orig. sizes and I'm curious to see how things end up. I did manage to decipher the P/N's and find a source, so now it's just a matter of inspecting the head/valves and getting a set of cams. I was told they're on back order :banghead: . Andy
