New to the list.
Details of my "7": Birkin S3 build completed 2013 (I purchased it completed)
Engine
Ford Zetec E 2.0 litre
VVT system deleted
Euro style cylinder head, mild porting and matched to intake 11.25:1 compression
Dunnell ZRV camshafts
Solid lifters
Dunnell valve springs and retainers
Dunnell intake and exhaust valves
Dunnell variable alloy cam wheels
ARP rod bolts
Solid cambelt tensioner
Custom cam cover
Race Tech water manifold
Race Tech low profile alloy oil pan
Stainless steel headers
Jenvey 45mm individual throttle bodies
Haltech fully programmable ignition system
Haltech fuel pressure regulator
Birkin alloy bell housing with concentric release bearing
Ford Type 9 Sierra gearbox with quick shifter kit, 5 speed
Disc brakes all around with twin master cylinders and balance bar
Adjustable coil over shocks
Quick release steering wheel
Full weather equipment
Full tonneau cover
  • 1 month later...
Yes pix (incl of dyno sheet:)). Interesting that a '13 Birkin has a Zetec, I guess the build was started earlier than '13? Birkin switched to Duratecs in '09 or so. Does it run on pump gas with 11.25:1 compression ratio? What is a quick-shifter kit(shorter throws?). All cool stuff.
Edited by Kitcat
Welcome aboard....but you can’t tease us with details and no photos.
.........:lurk:
