I'm about to embark on a 7 project and am looking to put together a powertrain to drop in it. I am currently planning on a stock 2.0 Duratec with throttle bodies and aftermarket ECU, coupled with a T9 5-speed and likely a 3.92 diff with Quaife ATB.
Before I start sourcing parts, I thought I'd see if anyone has any of these bits. For example, 2.0 Duratec long block.
Cheers!
  • 3 weeks later...
I have some Duratec accessories if you end up needing them. New starter, cam covers, stock cams, ITG air filter for the ITBs...
Good luck
Good luck
Thanks, I’ll let you know!
