I've got a front turn signal out so need to change the bulb. Can't see for sure how to get the beehive off to access the bulb.
Appreciate the advice to change the bulb.
Thanks,
Jim
Jim, I seem to recall when I assembled my car they they just press fit into the rubber gasket, the trim ring just presses in as well. A bit of a pain to get them in but I'm pretty sure there are no bolts or screws involved.
Tom
I carefully use a pick to remove/replace. Just run it between the underside of the rubber gasket and the top of the lens (or metal trim ring if you have that style) and pry down as you pull up on the lens. There is generally a lot more swearing and need for alcoholic beverages when attempting to reinstall it.
Thanks guys. Looked like it might pull off put didn't want to pull too hard and break something.
I'll have a beer before I try to put it back together!
Jim
