SK400 Posted September 27, 2020 Posted September 27, 2020 Gang I wanted to upgraded my lap timing scientific capabilities from using my cell phone (yes it works) to something more official and bought an AIM Solo2 DL. Since my car is a relatively modern Caterham (2013) it has an ODii port and chose to buy the Solo2 DL with ECU reading and connection capability. I’ve flashed the device using the software provided and chose the “Caterham 420r” écu option but to no available. My Aim Solo2 does not seem to pick up engine readings and not even RPMs any advice on how to best co figure this device for ÉCU ODii reading? I have the stock Caterham ÉCU. thank you very much Seb
fastg Posted September 27, 2020 Posted September 27, 2020 Are you on this list? https://www.aim-sportline.com/download/doc/eng/SintesiECU-OBDII_eng_118.pdf
Croc Posted September 27, 2020 Posted September 27, 2020 (edited) Seb - Set the car brand to be "Noble" It will work then. Noble uses the MBE ECU like the Caterham. While the data plug is J1962 format and CAN it is not OBDII. Example data from my Caterham Edited September 27, 2020 by Croc
